pto on 318 disconnects
3 replies to this topic
#1 ldone OFFLINE
ldone
  • 9 posts
Posted October 07, 2011 - 05:19 PM
This has become a problem. I have to repeatedly flip the pto switch back and forth watching the light blink off and on until there is solid engagement and the light stays on.
I have replace the pto with a new one.....no change
I have checked the voltage output....~14.2v idyling or revved up.....drops to ~13.8 when the pto is engaged.
seat cutoff switch is wire nutted together.
20a relay is ok
3 amp fuse is ok
starts and runs good
not sure where to look next
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 07, 2011 - 06:47 PM
Welcome to GTTAlk. What about the PTO switch itself. They tend to go bad with age. You need to use an ohmmeter to measure the contacts. You should have a very low resistance when the switch is closed. An ohm or 2 is all it takes to prevent the PTO from engaging. Also, have you checked the - side of the PTO coil to make sure it has a good connection back to the battery - terminal.
#3 big red dog OFFLINE
big red dog
  • 22 Thanks
  • 81 posts
Posted October 07, 2011 - 07:50 PM
Broken wire??? Ohm meter...
#4 ldone OFFLINE
ldone
  • 9 posts
Posted October 07, 2011 - 10:30 PM
Thanks fellas, will check pto switch tomorrow
