Cozy Cab on JD 318
2 replies to this topic
#1 shredwad OFFLINE
shredwad
  • 10 posts
Posted October 07, 2011 - 01:57 PM
Does anyone have a Cozy ROPS cab installed on their JD? If so, did you put something between the cab and the fender to prevent it from rubbing/rusting? What did you use?
Thanks!
#2 shredwad OFFLINE
shredwad
  • 10 posts
Posted October 07, 2011 - 02:00 PM
842f_1.JPG This is the cab I have installed on my 318...
#3 stoon boy OFFLINE
stoon boy
  • 1 Thanks
  • 6 posts
Posted October 08, 2011 - 06:14 PM
Where I bolted the cab to the fender deck, I used some 1 inch thick rubber washer, that compress when you tighten the cab down, works as a cushion and doesn't rub off the paint.
  • shredwad said thank you
