Woo Hooooo another JD430
85 replies to this topic
#61 MH81 OFFLINE
  • 29,979 Thanks
Posted November 06, 2011 - 10:24 PM
Was that one on the Titanic? Wow, that's bad.
#62 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted November 06, 2011 - 10:46 PM
Congrats on stealing the 430, Sure you and dan can fix it quickly.
#63 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted November 06, 2011 - 11:23 PM
Fred, You weren't mowing that grass, you were scarin it into layin flat on the ground...
:bigrofl::bigrofl::bigrofl::bigrofl::bigrofl::bigrofl:
Man, I knew you should have made the trade with me, It is an amazing machine and has more power then you can handle..:poke: GREAT JOB!!!!:worshippy2:
Thanks everybody, seat pan coming back off tonight to fix lift problem. Too much travel in linkage to lift the deck.
#64 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted November 07, 2011 - 08:06 AM
Glow plug relay. Was hoping I could clean the contacts and get it working--- not gonna happen. Anybody have a extra one??
[ATTACH=CONFIG]24407[/ATTACH]
We don't need not stink-in' reeellaaay!
#65 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted November 07, 2011 - 08:25 AM
Fred's handling all this one on his own. You have learned well Grasshopper! :dancingbanana:
#66 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted November 07, 2011 - 10:46 AM
That's TOO funny!! :bounce:
#67 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted November 07, 2011 - 10:48 AM
AT $60 I'm not getting one either. Have to take a picture of my temporary work-around tonight...
#68 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted November 07, 2011 - 11:00 AM
Country tractor enginuity at it's best!
#69 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted November 07, 2011 - 09:17 PM
Here is my glow plug relay work-around. :orangecool:
#70 MH81 OFFLINE
  • 29,979 Thanks
Posted November 07, 2011 - 09:25 PM
[ATTACH=CONFIG]24481[/ATTACH]
:bigrofl: looks like a pretty easy wiring job. Sometimes the simplest way is best.
My neighbor growing up, had a Perkins D. He had an old fashioned starter button on it. Like used to be in the MH tractors of the 40's.
#71 KennyP OFFLINE
  • 40,925 Thanks
  • 47,117 posts
Posted November 08, 2011 - 06:32 AM
I have to agree with Daniel on this one!
#72 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted November 09, 2011 - 07:57 PM
Butt-ugly...
But functional :smile1:
Decided to check the light switch to see if it worked and it was good to go. :dancingbanana:
I have had these lights for at least 10yrs. Picked them up at the flea-market and figured the would be good for something someday. 55 watts each so I was afraid they would blow a fuse but so far so good.
#73 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 09, 2011 - 08:10 PM
Fred you may be able to adapt a standard automotive relay to run the glow plugs. 60$ is ridiculous for a relay. Those lights should do the job and are probably way brighter than what came on it.
#74 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted November 09, 2011 - 08:19 PM
Factory lights leave allot to be desired on most JD's. In the summer, sometimes I wait till dark and it cools down to mow. No way I will give full price for a relay, my rigged-up setup works just fine for now but I will keep watching on E-bay. :smile1:
#75 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted November 21, 2011 - 08:57 PM
Tire ballast. Got a pump from HF and a adapter from Gemplers. Pump would not prime itself :mad2:
Plan B, stuck the whole pump in the bucket and it worked great! 32gals and 264lbs all-together in 4 tires. :dancingbanana:
