Electrolysis Question
12 replies to this topic
#1 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted October 05, 2011 - 06:34 PM
Had a good day today with my electrolsis tank ( used a plastic trashcan - rebar tied with wire.....one piece down 200 to go :smile1:
The next piece I am working on has an aluminum sears tag on it....I have submerged it down to right below the tag because I was concerned it would take what black paint/lettering that is left off....that a fair assumption?
Has more rust above that I can do by hand if I have too.......
#2 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted October 05, 2011 - 06:46 PM
I would say you 100% correct. Have been doing some items today myself.
  • sacsr said thank you
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted October 05, 2011 - 06:52 PM
I have taken the tags off by driving the rivets back thru. As far as I know, the holes go clear thru and a small nail set or punch will drive them back.
Edited by MH81, October 05, 2011 - 11:00 PM.
#4 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted October 05, 2011 - 08:38 PM
I can't remember for sure, but I think I remember reading somewhere that depending on what electrolite(is that the term?) you use, it can make short work of anything aluminum. Better safe than sorry.
#5 olcowhand OFFLINE
  • 42,885 Thanks
  • 31,934 posts
Posted October 05, 2011 - 08:39 PM
Nope, don't dunk the plate!
#6 FirefyterEmt OFFLINE
FirefyterEmt
  • 451 Thanks
  • 855 posts
Posted October 11, 2011 - 01:08 AM
On a side note: Place duct tape over the rivet that holds the tag. If you don't, it's as good as gone and you will never see it again!
#7 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted October 11, 2011 - 02:03 AM
The rivits are steel, the tag is not. It only takes a couple seconds to push the rivits out from the back side. i do it all the time. Put the rivits and tag is a zip lock bag inside your tool box so you dont lose the best part of the attachment. One with out the tag is worth about half the price.
#8 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted October 12, 2011 - 06:33 AM
What do you use to "push" them out? I tried a few things I had on hand and it bent what I was using to knock them out.
Thanks,
Scott
#9 KennyP ONLINE
  • 40,837 Thanks
  • 47,074 posts
Posted October 12, 2011 - 06:39 AM
The ones I took out came real easy with a small pin punch. I hope someone hasn't mashed them.
#10 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted October 12, 2011 - 08:30 AM
I am going to have to buy a punch set.....really only have 2 larger ones.....thanks
#11 FirefyterEmt OFFLINE
FirefyterEmt
  • 451 Thanks
  • 855 posts
Posted October 12, 2011 - 03:33 PM
Yea, you really need a good pin punch. If you use something tapered, like an awl, you "could" crack cast iron from the stress. FYI, a set of transfer punches are not a good choice, they like to bend. (tried it, failed with it) However, I think a set of transfer punches are almost mandatory in a shop. I find tons of uses for them!
Here is a tag that was removed and restored on a wood lathe I rebuilt.
Edited by FirefyterEmt, October 12, 2011 - 03:46 PM.
#12 MH81 OFFLINE
  • 29,978 Thanks
Posted October 12, 2011 - 06:12 PM
:ditto: I actually used an old nail set. It was a small one that fit perfectly.
#13 KennyP ONLINE
  • 40,837 Thanks
  • 47,074 posts
Posted October 12, 2011 - 06:36 PM
That probably would have worked also. They came out easily.
