Differences Between Kohler’s Kt17 Series I And 2 Engines.
  • This topic is locked This topic is locked
1 reply to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,464 Thanks
  • 15,392 posts
Posted October 05, 2011 - 08:53 AM
Differences between Kohler’s KT17 Series I and II engines.
If the spec numbers sticker is gone, the tag is missing. Here are pictures of the front right corner that will let you se the difference between KT17 Series I and Series II engines. The first picture is of the engine in one of my 317's with some of the sheet metal removed. This first picture of a Series II engine shows at the bottom a trapezoid-shaped blank cover for an optional oil filter port. The raised cover is held in place with 1/4” Allen head screws. If your engine has this blank cover it is a Series II. Also,I have been told, but not seen one personally, that some Series II engines did not have the oil filter option (so NO blank cover). An even better way to tell which engine you have is to look at the shoulder in the top of the picture. This shoulder is part of an internal oil channel. In a Series II the channel drill hole is closed with a threaded Allen head plug (1/16” pipe thread and 5/32” Allen pipe plug in earlier Series II, or 1/8” pipe thread and 3/16” Allen plug in newer Series II). Notice that the plug extends just above the shoulder.
In this second picture of a Series I engine there is obviously no oil filter port cover. Also notice that the shoulder does not have a raised Allen head plug. The oil channel is closed with a Welch-type plug. It may look like it has an Allen head, but if you clean out the dirt you will see it is round and indented—a Series I engine.
Fellow Member "JDBrian" found that in the Kohler KT Service manual the break in the Spec numbers to show where the Series II engines start.
JDBrian Said;
I found the Spec no. info. All engines with Spec No. of 24300 or higher are series 2 engines. It's in the Kohler KT service manual near the front.
Thank so Much JD.!!
Some of this Information was gathered from other sites. I do own both the engines in the photo's in this post. Thanks to Harold Goff for posting this info on wfm.
Edited by Texas Deere and Horse, September 01, 2013 - 11:40 AM.
Make Photo's Work
  • mjodrey, Tmo, crazyhorse and 4 others have said thanks
  • 14,464 Thanks
  • 15,392 posts
Posted September 01, 2013 - 11:42 AM
Thanks to JDBrian for the info on the Spec number break between the Series I and Series II engines. The thread has been updated.
