73 JD 110 newbie
7 replies to this topic
#1 willie989 OFFLINE
willie989
  • 5 posts
Posted October 05, 2011 - 06:06 AM
I have a 73 JD 110,replaced battery to start engine and nothing happens seems to be dead. Any suggestions would be greatly appreciated. thanks.
  • 14,889 Thanks
  • 15,514 posts
Posted October 05, 2011 - 09:24 AM
Check the battery to see if it's dead. If it is, then you have a drain on the system when the key is off. The ignition switch could be bad. If the battery is charged, then I would check the main ground at the chassis first, then go to the starter and check the positive connection, also at the solenoid. Make sure all these connections are clean. If these are all good, start checking for safety switches.
#3 mjodrey OFFLINE
Posted October 05, 2011 - 09:48 AM
Make sure the power is actually going through the solenoid when it is activated.If it isn't,you most likely need a solenoid.Do you have power to anything else?
#4 willie989 OFFLINE
willie989
  • 5 posts
Posted October 05, 2011 - 10:05 AM
Yes battery is new solenoid is new and switch aslo,it does not engage starter to crank engine.Thanks.
#5 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted October 05, 2011 - 04:38 PM
Make sure your PTO is "off". I also have a '73 110, and sometimes, if the PTO lever isn't fully disengaged, it won't allow the starter to work.
#6 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted October 05, 2011 - 04:55 PM
Dont forget the neutral safety switch by the gear shift.
#7 lyall ONLINE
lyall
  • 2,228 Thanks
  • 1,594 posts
Posted October 05, 2011 - 08:52 PM
also check the circuit breaker. it is rare they go bad, but they can. it should be close to the solenoid
check the wiring harness for any bear wires. and rusty connections
#8 willie989 OFFLINE
willie989
  • 5 posts
Posted October 06, 2011 - 05:49 AM
Thanks for the help it was a bad solenoid,and thanks again.
