bolens paint codes
18 replies to this topic
#1 brownboystoys OFFLINE
brownboystoys
  • 121 Thanks
  • 146 posts
Posted October 04, 2011 - 07:58 PM
I am looking to find bolens paint codes so I can start painting the 1959 bolens ride a matic. I have been lucky finding parts but still looking for more attachments.any help with paint codes would be helpful. Jody
#2 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted October 04, 2011 - 08:54 PM
There is no paint codes, use a part of the tractor with good paint on and take it to a car parts store that makes paint and they should about make a copy it.
  • brownboystoys said thank you
#3 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted October 05, 2011 - 12:45 AM
I took my parts to NAPA and they mixed the colors, ready to pick up the next day. Lots of good help from them also!!
  • tractorman604 said thank you
#4 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 05, 2011 - 04:31 AM
Yes,NAPA does a good job scanning,and color matching for me.
#5 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 05, 2011 - 05:11 AM
Yes Napa has a good scanner but yo need a piece minimum of 6X4 inch with clean paint to get a good match. I was there yesterday and part was to small to scan.
#6 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted October 06, 2011 - 12:18 AM
Napa also has color chips that match up preety darn good. just another thought.
  • awol said thank you
#7 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 06, 2011 - 11:41 AM
Speedyg was right Napa has a exact paint match in a chip for my 1225, it's called Persian ivory.
It cross references with a GM paint that was used in 1967 on there Cadillac's. It not cheap but you won't find a closer match IMO.The paint sample was from under the sticker.
Edited by awol, October 06, 2011 - 12:12 PM.
  • Bolens 1000 and mjodrey have said thanks
#8 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 06, 2011 - 12:34 PM
I think there should be a sticky for paint and colors that we come across. It seems a lot of us would benefit from this. Not trying to hijack the tread but it makes sense to me.
#9 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 06, 2011 - 02:05 PM
I see you're using Nason single stage urethane paint.That is pretty good paint,I use it quite often.
What is the paint code for that color? It would be on the can.
#10 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 06, 2011 - 02:41 PM
The formula # is 682526
#11 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 06, 2011 - 03:42 PM
No,that wouldn't be the paint code. I am very interested in the paint code,do you think you could get it for me at NAPA?They should have put it on the can.
#12 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 06, 2011 - 04:20 PM
I will see if there is a number for you. I did find this from Dupont.
http://www.hartparro...nload.php?id=54
#13 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 06, 2011 - 05:03 PM
Ok I've done some searching, and G.M.'s paint code for the 1967 Cadillac Persion Ivory appears to be 40.
EDIT:
No, wait,I just dug out my old R-M color chip book that goes back to 1959 ,and they don't show a Persion Ivory.They do show a Kashmir Ivory # 40,but it looks too yellow.
There is one just called white,code 12 that looks right.Of course color chips are not necessarily accurate.
Edited by mjodrey, October 06, 2011 - 05:19 PM.
#14 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted October 07, 2011 - 06:58 AM
I added another sticky thread on paint codes:thumbs:
#15 wolfen1176 OFFLINE
wolfen1176
  • 5 posts
Posted November 03, 2011 - 12:12 AM
My 1220 that I am in the process of restoring doesn't have any part big enough to get a good scan for the original brown on the frame. I did remove the PTO decal and it appears to be a metallic color. Were these painted with metallic paint? Any good paints people have found to use for the brown frames? I would prefer to stick with the automotive paints as that is what I'm familiar with spraying.
