kohler k532 flywheel rotation
22 replies to this topic
#1 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 04, 2011 - 05:30 PM
so i was gonna see for myself but my kohler took a **** today, wont turn, starter grinds. so does the flywheel turn CW or CCW? im getting a kubota engine for her and i just need to know for obvious reasons. thanks!
#2 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted October 04, 2011 - 05:44 PM
Just take a look at what direction the fins on the flywheel are pointing and you will be able to figure out rotation......
#3 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 04, 2011 - 06:02 PM
the fins would want the air to blow "into" the motor correct?
#4 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted October 04, 2011 - 06:05 PM
Correct
#5 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted October 04, 2011 - 07:39 PM
Looking at the flywheel, it turns CW.
#6 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 06, 2011 - 08:34 PM
now i wonder what direction this kubota engine is going to turn. it it turns CW im in great shape. tlest i should be. i just about have the kohler out, im so excited!!!!!
  • 15135 Thanks
  • 15577 posts
Posted October 06, 2011 - 08:36 PM
If it turns the wrong direction, mount it the other way...
#8 olcowhand ONLINE
  • 44107 Thanks
  • 32302 posts
Posted October 06, 2011 - 08:38 PM
If your hydro shaft hooks to the flywheel, then the hydro will have to be driven from the pulley end (front) of the diesel engine to turn the hydro in the right rotation.
#9 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 06, 2011 - 08:57 PM
either way the rotation will work. both ends have a stub shaft somewhere. so ill see the engine on saturday,
#10 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 07, 2011 - 04:43 AM
That is correct,always CW.
#11 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 07, 2011 - 05:45 AM
dont some diesels turn CCW?
#12 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 07, 2011 - 06:01 AM
I believe all air cooled engines turn CW,if you view them from the flywheel end .
And most,if not all liquid cooled engines turn the opposite direction,if viewed from the flywheel end.
Edited by mjodrey, October 07, 2011 - 06:21 AM.
#13 mikebramel ONLINE
mikebramel
    Ron Paul
  • 181 Thanks
  • 1009 posts
Posted October 07, 2011 - 08:35 AM
They both turn the same way looking at them from the front, because the flywheel on the air cooled is the front and the flywheel is the backside on the water cooled
#14 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 07, 2011 - 03:04 PM
ok so whe i mount the kubota the flywheel will face me when i sit on the tractor?
#15 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted October 07, 2011 - 03:08 PM
No, flywheel to the front of the tractor.
