H048G mower deck
6 replies to this topic
#1 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted October 03, 2011 - 09:34 PM
I pulled the deck off last weekend to do some core aerating and now have it laying in the garage. I'm considering rebuilding or replacing the spindles and idler while it's off. Does anyone have the correct part numbers for doing so, or if previously answered, point me down the right path. I've searched but not found p/n's yet. The entire Serial number is H048G 390740M.
Having greasable zerts would be a bonus.
#2 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted October 04, 2011 - 07:42 AM
Hi Terry,
From what I can tell so far you have a 48 deck that shares many parts with the model 41 I have on the 120. If I am correct then the following is what you need. To be sure a picture of the deck would help me narrow it down.
From JDParts.com
KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 P48362 LOCK NUT 3
2 AM105652 PULLEY 2 (114.30 MM) 4-1/2" O.D. (48) (SUB FOR AM31004, AM37308 AND AM103859)
AM37309 PULLEY 2 (95.25 MM) 3.75" O.D. (41) (SUB FOR M41628)
3 26H14 SHAFT KEY 3 3/16" X 3/4"
4 24H1184 WASHER 1 - XXXXXX 25/32" X 1-1/4" X 0.105", (41) (L.H. SPINDLE ONLY)
5 AM33097 PULLEY 1 (177.80 MM) 7" O.D. (48)
M47713 PULLEY 1 (151.38 MM) 5-13/32" O.D. (41)
6 24H1184 WASHER 1 25/32" X 1-1/4" X 0.105", (48 CENTER SPINDLE ONLY)
7 JD9296 BALL BEARING 6 (45.97 MM) 1-13/16"
8 M73515 SPACER 1 (45.97 MM) 1-13/16", (SUB FOR M45121)
9 M45273 HUB 1 (SUB FOR AM107500)
10 J2376M SNAP RING 6
11 AM32955 HUB 1 (153.40 MM) 6"
12 AM39918 SHAFT 1 (153.40 MM) 6", (INCLUDES 19H1740) (SUB FOR AM33680)
13 AM39964 SHAFT 1 (48 ONLY) (SUB FOR AM31164)
14 24H1294 WASHER 9 11/32" X 1-1/8" X 1/16"
15 03H2126 BOLT 9 5/16" X 1-1/8"
14H785 NUT 9 5/16"
16 M40634 THRUST WSHR 3
17 19H1740 CAP SCREW 3 7/16" X 1-3/4", (41)
19 H1821 CAP SCREW 3 7/16" X 1-1/4", (48)
18 M41967 BLADE 3 (48) (CAP SCREW NO LONGER INCLUDED) (SUB FOR AM31100)
M41237 BLADE 3 (41) (CAP SCREW NO LONGER INCLUDED) (SUB FOR AM30698)
19 AM39916 SPINDLE 2 (108.7 MM) (INCLUDES 19H1740) (SUB FOR AM33098)
20 M11031 HUB 2 (SUB FOR AM107466)
21 M40636 SPACER 2
22 AM30302 HUB 2
23 M45127 HUB 2 (A)
(A) SUB AM39916 FOR RH AND LH SPINDLES; SUB AM39918 ON CENTER SPINDLE.
If you want this info in an easy to read format I have it in a word doc that I created. I can email it to you unless there is a way to attach it here.
Edited by Trav1s, October 04, 2011 - 07:50 AM.
Formatting problems
  • TerryD said thank you
#3 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted October 04, 2011 - 08:23 AM
Thanks Trav1s. I'm at work so unable to snap a pic. These look just as my spindles do, so I believe this is the correct schematic. The S/N was on an aluminum tag just behind the discharge chute on the right side, and of course there were covers over the spindles which I intend to leave off. There is a single roller up front and narrow wheels on the back with the left one having a 1/2" round bar that is "J" shaped coming off the left rear wheel support and turning down to where it is welded to the deck. The right one doesn't have this extra support, but both have a flat triangular support welded at about a 45 deg angle from the rear wheel uprights down to the deck.
#4 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted October 04, 2011 - 09:21 AM
From the latest post I believe that we have the right one. I will email the doc to you in a few. The formatting is much better.
#5 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted October 04, 2011 - 10:05 AM
Got your email and it should be in your possession now or very soon.
#6 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted October 04, 2011 - 08:19 PM
Did you get it Terry?
#7 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted October 04, 2011 - 10:21 PM
I sure did. Thank you very much for that. I called the local Deere dealer to check parts availability and prices. They have most everything in stock. I think I am going to go ahead and replace the bearings, one of the spindle pulleys, and the idler. I'm waiting on the penetrating oil to do it's job before I tackle it.
Thanks again for the schematic.
