Tranny lube viscosity
5 replies to this topic
#1 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted October 03, 2011 - 08:09 PM
I'm looking through my wheel horse 857 manual for trans service and it makes no mention of viscosity when changing fluid out.
Thought I should ask here so I don't mess anything up. The PO never changed it himself and wasn't sure when it had been. The trans is quiet and smooth as it is. What do you all use/recommend? I have some 75w90 on hand. :smile1:
#2 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted October 04, 2011 - 11:20 AM
Never mind, I found the info. Requires sae 40, seems light to me.
#3 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,468 Thanks
  • 2,809 posts
Posted October 04, 2011 - 11:47 AM
there are hardly any trannys that require a heavy oil, in fact the heavy oil is hard on most of them. Even things as big as semi tractor only use 50# oil in the transmission.
#4 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted October 04, 2011 - 03:12 PM
I went to my local auto parts store and they didn't even have straight 40 oil. Bummer.:confuse:
  • 14,472 Thanks
  • 15,392 posts
Posted October 04, 2011 - 04:30 PM
Check with NAPA, if they don't stock it, they will order it.
#6 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted October 04, 2011 - 04:43 PM
Ha, found two Un-opened qts in my garage. They are probably 20 years old, are they still good I wonder?
