Ebay rebuild kits
4 replies to this topic
#1 poncho62 ONLINE
poncho62
  • 1,996 Thanks
  • 1,744 posts
Posted October 03, 2011 - 07:05 PM
Gonna tear into my cast iron Kohler (K301, 12hp).......So far, it looks like I need a rod, had a bit of a knock.......Looking at these kits on Ebay....heres an example
ENGINE REBUILD KIT FOR KOHLER K301 12HP FREE TUNE UP | eBay
Anyone have any experience with these kits, from this guy or others?...pros...cons
#2 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted October 03, 2011 - 08:10 PM
Yes. I bought one about a year ago from ebay for a 16hp kohler for our 316K. Wasn't that guy, but one of the others - don't remember the name at the moment. Same type of thing - bought the basic kit and added a rod because I had to have the crank journal ground smooth.
Can't complain about the transaction or parts. Everything worked ok. My machne shop didn't complain about the parts. Just look at the guys feedback and comments - make sure he has been on the site for a while and has no/few negative comments. There are/were about 5 different venders that had my parts at pretty much the same price. Look around though - there was quite a difference in how much you could get the stuff for. Good luck!
  • poncho62 and MH81 have said thanks
#3 MH81 OFFLINE
Posted October 03, 2011 - 10:06 PM
This vendor may be the answer to my Kohler on my Troy built tiller.
#4 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted October 03, 2011 - 10:32 PM
check your valves before you order. You might need the valves, too. Looks like the same guys said the kit with valves for around $104 plus $10 shipping
keeps us posted how it goes
  • poncho62 said thank you
#5 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted October 04, 2011 - 08:59 AM
Yea, I forgot to mention the valves/guides. If you are having machine work done anyway, usually the shop can match your new valves in and grind/lap the seats for a few extra bucks. Some kits come with valves, others are a add on. Same with your guides - easy to replace while the block is apart and in the shop. IF your guides are worn, new valves won't do a lot of good. Easy to replace in the Kohlers, but they have to be reamed to your valves.
For the few extra bucks, I replaced both valves and guides (one valve was bad, one guide on the edge of tolerance). Unless you are just doing a quick fix, it makes sense to not cut corners. The iron Kohlers will last forever if cared for.
