Bolens 1225
27 replies to this topic
#1 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 03, 2011 - 03:38 PM
So today I had some time to start prepping the sheet metal on my 1225, I picked up a 10 gallon pot sandblaster and 26 gallon compressor at a estate sale for $200.00. They were never used and I couldn't pass it up. The compressor is a little under size for the sandblaster but if you take you time it works OK. I got the tri-chrome rings in last week and my daughter was looking at them and you know now what happend:wallbanging:Oil ring in two pieces. It was the only set available at Rock creek consulting, so I will see if I can find another set.
#2 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 03, 2011 - 04:19 PM
Nice looking equipment.Good looking job.
  • awol said thank you
#3 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted October 03, 2011 - 04:23 PM
It looks like the sandblaster/compressor did a nice job on those pieces. For 200$ I can see why you couldn't pass it up.
#4 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 03, 2011 - 04:36 PM
I just need to find the best way to remove the decals. The sandblaster won't do it so maybe some elbow grease and some solvent might do the trick????
#5 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted October 03, 2011 - 04:49 PM
Try using a heat gun to loosen them. I had a bunch of them to remove from my 314, some of which had been painted over. The heat gun and a small scraper got most of it off and solvent finished the job.
I learned that trick here on the forum. Just passing it on.
#6 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 03, 2011 - 04:51 PM
You could try soaking the decals with Lacquer thinner to soften them up.
#7 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 03, 2011 - 04:53 PM
Thanks for the info Brian, I will give that a try.
#8 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 03, 2011 - 04:54 PM
Thanks Maynard I will try that as well.
#9 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 03, 2011 - 07:34 PM
Nice buy on the Blaster
Looks like your making good progress :thumbs:
#10 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 05, 2011 - 01:30 PM
Got a few more things done today, that sandblaster sure makes short work of removing the paint!!:bounce:
#11 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 05, 2011 - 01:49 PM
You are making good progress.
#12 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 05, 2011 - 07:02 PM
:ditto:
#13 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted October 05, 2011 - 11:57 PM
awol, looks real good. are you able to recover some of your sand? and how long did it take to strip your hood?
#14 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 06, 2011 - 03:38 AM
Yes I have a tarp setup that recovers about 20%, as for the hood if I include the decals about a hour. I ended up using a razor blade scraper to remove the decals and some goo gone.
#15 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 06, 2011 - 11:48 AM
Some more pic's I think is's ready for primer and paint
