Variator button release
2 replies to this topic
#1 mehs1970 OFFLINE
mehs1970
  • 3 Thanks
  • 20 posts
Posted October 03, 2011 - 08:34 AM
In order to adjust the variator, I have to push really hard on the button, which is tough to do when the thing is moving. It almost takes two hands. My right thumb isn't strong enough.
Any ideas? :anyone:
Larry
#2 MH81 OFFLINE
Posted October 03, 2011 - 11:36 AM
On my last 10 that I had to work on, I had to unscrew the thumb button and remove the rod & spring then clean up the tube. I also remember that on Ryan's, he does have to pull back slightly before pushing the button or it's a little stiff for a 13 yr old to run.
  • mehs1970 said thank you
#3 lyall ONLINE
lyall
  • 2,169 Thanks
  • 1,573 posts
Posted October 05, 2011 - 10:09 PM
try spraying it with WD40 or something to see if it loosen up any.
I try to grease or spray any parts that can move, helps a lot on maintain problem in the future.
