How much can a loader on a garden tractor lift? Deere 110 loader project?
#1
OFFLINE
Posted October 02, 2011 - 10:04 PM
So on to my questions! How much can you practically (safely) lift in a bucket on a 500-700 lb tractor? And with most of these being 1 or 2 wheel drive, doesn't traction become an issue? I have experience with bigger tractors/loaders, but never with a garden tractor.
I have two possible platforms - a 110 round fender, and a 316k. I have a set of plans for a standard type loader and would probably size it to fit the platform and build it myself unless I could get a good deal on an existing one. The 110 has NO hydraulics at all, so I would have to go with an engine driven pump. The 316k has hydraulics, but would there be enough flow to support a loader off the internal system? Would it be better to use a seperate pump/hydraulic system on that one as well?
Are the front axles/wheels/frames on these up to the added load of a loader (no pun intended...:blush2:)?
Are most loaders mounted to the frame or is a subframe member added to spread the weight to the rear axle?
I have most of the tubing, plumbing and valves for a loader system, so am not too concerned about the cost, and building it would be fun. But I want to make sure it will be productive enough to warrent the time and effort. I don't expect to lift the front end of cars with it, but would expect to ba able to move some cinder blocks or a load of dirt if needed.....
Sorry for all the questions, but There always seems to be someone out there who has good answers to all my questions!
#2
ONLINE
Posted October 03, 2011 - 07:02 AM
If I were to choose the 316k is a no brainer. The hydrostatic drive would be a huge benefit when working. I would even consider adding power steering on the tractor.
#3
OFFLINE
Posted October 03, 2011 - 07:37 AM
Think of the the hydro lever, the steering wheel and the loader control valve and only 2 arms. It least you would want the loader control valve on the opposite side as the hydro lever.
Don't forget the can holder either.LOL
#4
OFFLINE
Posted October 03, 2011 - 07:59 AM
#5
OFFLINE
Posted October 03, 2011 - 08:45 AM
The 110 you refer to did have a loader setup for them and was setup for around 300lbs max so it's really up to the needs you have for which tractor to use.The setup would be the same as the 316 just smaller.
- Tennblue59 said thank you
#6
OFFLINE
Posted October 03, 2011 - 04:37 PM
Another example. My 2320 with ballast weighs in at about 3200lbs. It can lift 620 to full height and feels safe doing it.
#7
ONLINE
Posted October 03, 2011 - 05:22 PM
I also agree with JDBrian on the weight. On totally flat ground, with plenty of rear ballast, maybe 400lbs max height, but on even the slightest of slope, never lift to max height, even with a light load. And NEVER drive with loader at full height, except to pull up to whatever you're dumping in. On uneven ground, just the weight of the loader arms & bucket at full height....you can tip over sideways. Duals really help reduce tipping.
FEL's are extremely useful. I do a LOT of true WORK with mine. They will dig a lot too, if your tractor is weighted enough. Mine is on a Massey 1855 with no subframe. You would likely do fine without an added subframe too.
I say do it! You WILL NOT regret having it once finished, and will never run short of jobs it can do for you. Also could save you thousands of dollars in back injury costs, and the extreme pain!
#8
OFFLINE
Posted October 03, 2011 - 06:52 PM
The JD 2305 and the 2320 used the same loader. When I hung out on MTF there were a number of instances where guys rolled their 2305's while using the loader. IMO it is not so much a weight issue in that case but the other factors, particularly the much shorter wheelbase and smaller tires. The smaller tires will sink more in soft material on the downhill side and cause the tractor to tip more which can lead to a rollover.
This is not something to play with. Designing a loader that's too heavy or strong for your tractor could get you killed. An alternative for those who don't need to lift material to load a truck or trailer is the Johnny bucket. It keeps the weight low and works very well on smaller tractors. You can even get a tooth bar for it to help it dig.
#9
OFFLINE
Posted October 03, 2011 - 07:57 PM
One good thing about this project would be that it would be used in FLAT Florida. I do know from experience that hills (we have some very hilly areas on our Tenn property) and slope make a big difference with loader comfort. I wasn't sure how the feel would be on the smaller (shorter wheelbase, smaller tires, lack of weight and no 4 wheel drive...) platform.
#10
OFFLINE
Posted October 03, 2011 - 08:01 PM
Go with the 316. Bigger is better. Get wheel weights and fill the tires. I keep the tiller or rear scraper (with some extra concrete weight) on for a counter weight too. Keep the loader as close to the ground as you can, full or empty (same as in a full-sized loader or a forklift...safety rules never change) and be careful on hills and uneven ground. A loader is the most useful accessory you'll ever have.
#11
OFFLINE
Posted October 04, 2011 - 03:19 PM
Go with the 316. Bigger is better. Get wheel weights and fill the tires. I keep the tiller or rear scraper (with some extra concrete weight) on for a counter weight too. Keep the loader as close to the ground as you can, full or empty (same as in a full-sized loader or a forklift...safety rules never change) and be careful on hills and uneven ground. A loader is the most useful accessory you'll ever have.[/QUOTE]
Agreed. You will use it all the time for lifting anything heavy or awkward. I suggest looking into a ballast box if you have a 3pt hitch. Also make sure your front tires are in good shape and inflated to the max. pressure.
#12
OFFLINE
Posted October 04, 2011 - 10:50 PM
The concensus seems to be lots of rear weight, that folcrums the weight off the smaller front wheels and onto the stout rear axle (thats really what happens with rear hitch weight..).
You are adding a static load of 300-400 lbs fr counterweight, weight of loader (500 -1000 lbs?) plus payload (400 - 600 lbs), plus dynamic weight (lifting, bouncing, shifting, etc). Are Garden Tractor frames strong enough to take this kind of weight without twisting?
Obviously some models are, because there are members out there using them this way. Looking at the frame of my 316, is much thicker than the frame on my LX173 mower. Garden tractor vs lawn tractor?
If you were going to pick a garden tractor for loader duty, what would be some of the prefered models and why? Not trying to start a "my brand is better than your brand" war, just curious! I've only had Sears and Deere L/G tractors, so I don't know much else. If there were a platform head and shoulders better than my 316 to start with, I might try and do some trading around. So what's your loader hooked on and why does it work/not work?
#13
OFFLINE
Posted October 05, 2011 - 07:19 PM
#14
OFFLINE
Posted October 05, 2011 - 08:14 PM
Just for reference I believe the loader for the X700 series is rated to lift 400lbs to full height. That is with a ballast box and wheel weights. That is a bit much for safety IMO with a tractor as small as a 316. You can design it to lift a lot of weight but it won't be safe and you will likely break something. I would say 300lbs would be a good safe limit.
45loader at max lift height is 365Lbs. At transport height 640Lbs or 36inches if You shim it You can get 1200 to 1500lbs at transport height
40Loader same as 45 loader
44loader for 316Onan to 332 400lbs at Max height
420 & 430 with a 44loader 500Lbs at Max lift Height
Johnson Loader on a 110, 112, 140 and 200 thru 216 350lbs at Max Lift Height
Kwik-way Loader is about the same as the 44loader for the 316Onan to 332 or 420 & 430
#15
OFFLINE
Posted October 06, 2011 - 04:10 AM
