Low range went out on my Case 444
5 replies to this topic
#1 bigheter OFFLINE
bigheter
  • 7 posts
Posted October 02, 2011 - 07:19 AM
While working my Case 444 yesterday low range just went out, I still have high range though, can you tell me what might have happened? Thanks
#2 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted October 02, 2011 - 07:37 AM
I can't help you with the answer but I did rename your thread to give it a better description and to also keep people from thinking it is a duplicate of your other thread.
#3 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted October 02, 2011 - 02:14 PM
Internal damage or the linkage disconnected
#4 JDBrian OFFLINE
  • 9,601 Thanks
Posted October 02, 2011 - 03:54 PM
That doesn't sound good. Hopefully it's the linkage problem Mike mentioned above and not something major.
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 02, 2011 - 04:03 PM
I would not be driving it in high range until the problem is resolved. If a gear got stripped it would mean metal chunks in the transaxle oil. If I was you I would drain the oil out of the transaxle and check for metal chunks.
#6 Billygoat OFFLINE
Billygoat
  • 76 Thanks
  • 206 posts
Posted October 02, 2011 - 08:30 PM
There are clips on the shifting shaft that holds the shifting yoke in place. You may have lost one of the clips off of that shaft. That will allow the shifting yoke to move in one direction, but just slide on the shaft in the other direction. Can't guarantee that's the problem, but doesn't sound like catastrophic gear failure from your description.
