The 110...The one that started the addiction...
11 replies to this topic
#1 Bradz1st110 OFFLINE
Bradz1st110
  • 1 Thanks
  • 21 posts
Posted October 01, 2011 - 01:19 PM
This is the one that got me started. Picked it up on Ebay for $195. Came with 39 deck and a modified 43 blade. It ran pretty good surprisingly. I think the motor is off a Patio series. It's a 1970 and currently not running as I was out snowblowing last winter and it just sputtered and died. Come to find out the 2 screws on the throttle butterfly in the carb came out. I'm assuming the worse and guessing they got sucked into the motor. I havent ran it since. Need to investigate further, just hasnt been a priority.
Fresh off the trailer
After some soap and Turtle Wax
With my brass tag 37 blower
#2 mjodrey OFFLINE
Posted October 01, 2011 - 01:42 PM
I must say,I like that style.
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 01, 2011 - 01:51 PM
Thats a nice solid looking 110 with very nice attachments.
#4 Bradz1st110 OFFLINE
Bradz1st110
  • 1 Thanks
  • 21 posts
Posted October 01, 2011 - 02:49 PM
Thanks for the compliments guys. I think this one might be ready for semi-retirement. I had thoughts last night of converting the front end to a tricycle and maybe a repaint with a new hood. Possibly take it to some shows or just use it for a yard pig.
Edited by Bradz1st110, October 01, 2011 - 03:06 PM.
#5 MH81 OFFLINE
  • 29,978 Thanks
Posted October 01, 2011 - 06:04 PM
Nice 110 you have there. Sorry to hear about the screws. Hope it isn't bad.
#6 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted October 03, 2011 - 10:10 PM
As I get closer too retirement, I still plan on staying busy. Freshen the old boy up and give it a part time weekend job. It will thank you for it. Looks like there is plenty of life left in it.
#7 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted October 03, 2011 - 11:54 PM
The hood is in good shape. No chunks missing :) Nice find!
#8 Bradz1st110 OFFLINE
Bradz1st110
  • 1 Thanks
  • 21 posts
Posted October 04, 2011 - 09:38 AM
The hood has some sheetmetal riveted to the front of it. Looks decent but needs fixed correctly or a new one installed. I never changed it cuz it serves it's purpose.
#9 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted October 04, 2011 - 09:16 PM
Nice looking 110. Looks like it's had a full life(but with much more to go).
I had a Cub 129 swallow a butterfly screw, apparently the other had been eaten some time before. The throttle went a little haywire before it shut down, I assume from the no longer attached butterfly bouncing around then finally choking it out. I opened up the Kohler, and no sign of the screw. I believe they are small enough , it went through like the proverbial "substance" through a goose. But I would pop the head just to be sure.
#10 Bradz1st110 OFFLINE
Bradz1st110
  • 1 Thanks
  • 21 posts
Posted October 05, 2011 - 08:39 AM
Thanks Gibby. I think I'm gonna pull the head just to be safe. Also thought about a magnetic pickup tool thru the spark plug hole...
#11 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,551 posts
Posted October 05, 2011 - 09:02 AM
Pulling the head is pretty easy to do. Remember to lap the head and torque the bolts to spec.
Edited by Trav1s, October 06, 2011 - 08:02 AM.
#12 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted October 05, 2011 - 10:03 PM
I lost the two butterfly screw, too. Good thing mine were the brass one not the steel one. I remove the head and no damage to the piston or side walls. Got new screws from JD dealer with lock washers and used lock tite for the new screws, have not had a problem with the screw coming out again
good luck on your, hope they were brass
