Ford LGT125 restoration.........
9 replies to this topic
#1 poncho62 OFFLINE
poncho62
  • 2,250 Thanks
  • 1,835 posts
Posted April 29, 2010 - 06:23 PM
Actually, I am not much into these total restorations.....I got this tractor last week with a MF12 which I turned over to Doug (DH1).....I stripped all the bodywork off of it the other day, power washed it and got it fired up today. It runs OK, smokes a bit, but I figure it hasn't run in about 10 years, so it can only get better the more I run it. Drove it around the yard a few times, the hydro seems to function well...so, I guess I will clean up and paint the frame and start putting it back together......I am debating whether to fix the bodywork up or go with that rat rod look with the old patina etc.........Will add pics as I go along...if I think of it.
Would like to figure out the year, I know its from 71-76........
# on frame.....205270 N D1
Engine #s
K301AS
Spec.....474706
Serial....4026807
Edited by poncho62, April 29, 2010 - 06:28 PM.
#2 mjodrey OFFLINE
Posted April 29, 2010 - 06:26 PM
Nice ford,I have one of those on my want list.
#3 poncho62 OFFLINE
poncho62
  • 2,250 Thanks
  • 1,835 posts
Posted April 29, 2010 - 06:49 PM
Stripped down.......
#4 poncho62 OFFLINE
poncho62
  • 2,250 Thanks
  • 1,835 posts
Posted April 29, 2010 - 06:53 PM
The gas tank on this leaks slightly.......bottom has been repaired before.....Does anyone heard of a type of sealant that is put inside, sloshed around and let dry and it seals up the pinholes?
#5 mjodrey OFFLINE
Posted April 29, 2010 - 07:04 PM
I will see if I can find the name of that stuff.I did a Model A Ford gas tank with it last year.
#6 olcowhand ONLINE
  • 43,178 Thanks
  • 32,014 posts
Posted April 29, 2010 - 08:19 PM
I use "Kreem" fuel tank liner kits. NEVER had it fail ever even many years after lining. Motorcycle shops usually carry it, as well as JC Whitney, Dennis Kirk, and many other places.
#7 poncho62 OFFLINE
poncho62
  • 2,250 Thanks
  • 1,835 posts
Posted April 29, 2010 - 08:36 PM
Thanks....will check it out and see if I can get it locally.
#8 poncho62 OFFLINE
poncho62
  • 2,250 Thanks
  • 1,835 posts
Posted May 03, 2010 - 04:07 PM
Spent part of the weekend cleaning it up, painting the engine and frame........I am not stripping this thing right down, just making it look better.....I had to weld the steering shaft that goes through the steering box.....a common problem on these.......This morning, I laid the bodywork back on for a trial fit.
#9 NUTNDUN OFFLINE
  • 10,354 Thanks
Posted May 03, 2010 - 04:08 PM
This will be a nice project for you Poncho especially since you don't normally restore them :D Did you pull the trailer with your old ford pickup?
#10 poncho62 OFFLINE
poncho62
  • 2,250 Thanks
  • 1,835 posts
Posted May 03, 2010 - 04:13 PM
Yep....My truck pulls the trailer.......I have pulled a 19 ft house trailer all over the place with the truck.....Out to Indianapolis and down to the east coast, so its no big deal for it....I have a Reese electric brake controller on board........
