Sears Decals
5 replies to this topic
#1 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted September 29, 2011 - 07:05 PM
Does anyone know where i can get some decals made for my 1964 sears custom 600. My restoration is coming along better than i thought and should be needing decals in about 3 weeks.I'm not sure if terry the vinyl guy only does wheelhorse.
#2 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted September 29, 2011 - 08:15 PM
Try ebay. They're listed from time to time.
  • tractorman604 said thank you
#3 dthomp17 OFFLINE
dthomp17
  • 585 Thanks
  • 471 posts
Posted September 29, 2011 - 09:16 PM
I've had some success making my own decals using ink jet decal paper I found on ebay. Just followed the directions and it was relatively easy. You can see what they look like on my tractor.
#4 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted September 29, 2011 - 11:03 PM
nice decals. Not to knock them, but have you washed the tractor to see if the ink will run out. Been though that already, so now i just have the sign shop make them for me. Also there are a lot of guy making good stuff on ebay. Just go to David Bradley tractors and look at all the ones on there. Im sure there are looking for more demand on other types.
#5 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted September 29, 2011 - 11:48 PM
I created some similar decals for my SS16 (if I ever get to painting it). I laminated them hoping this would stop the ink from running. Crossing my fingers.
#6 dthomp17 OFFLINE
dthomp17
  • 585 Thanks
  • 471 posts
Posted September 30, 2011 - 08:44 AM
No the ink won't run when wet. In fact, I used "water-slide" decal paper to transfer the decal to the tractor. You have to spray the printed decal with Crystal Clear Krylon and let it dry before you transfer to the tractor. That keeps the ink from running. After it is transferred to the tractor and dried, you can spray another coat of Krylon to protect it even more. My main concern is how well will the colors hold up to sunlight before fading. My tractor is usually under cover when not in use so I don't expect much of a problem.
