Modification question
16 replies to this topic
#1 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted September 29, 2011 - 12:12 PM
Just picked up a 10" Ohio Steel Fabricators plow in what I consider good to very good shape. My question, has anyone ever modified the adjuster screw to a rotatable handle similar to ones on the Brinly. Or should it be left as is for what ever collectable value it might have?
#2 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted September 29, 2011 - 03:02 PM
I would upload a pic. for idears but the ADD A FILE thing won't let me, odd, never did that to me before,
a little cutting and welding and yes it can and has been done before, if i had the money i would go after a brinley and leave that one, in the end it is up to you,
#3 olcowhand ONLINE
  • 41,262 Thanks
  • 31,447 posts
Posted September 29, 2011 - 05:38 PM
You could add a crank style to it & not alter the plow itself at all. Could be put back to original condition in a matter of minutes.
#4 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted October 01, 2011 - 07:37 PM
Got a mod figured out in my head just need to put it on paper and see if it makes sense.
Don
#5 olcowhand ONLINE
  • 41,262 Thanks
  • 31,447 posts
Posted October 01, 2011 - 07:41 PM
Don
I had the mental pic too, but haven't had time to put it on paper to be understood. You likely have it nailed down.
#6 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted October 02, 2011 - 09:12 PM
Does this one have the multihole mount on it
#7 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted October 03, 2011 - 09:01 AM
If you are referring to the sleeve hitch area, yes it has three holes. Very much like the brinly plows.
Edited by brokenfeather, October 03, 2011 - 09:57 AM.
#8 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted October 03, 2011 - 06:29 PM
I have with 5 holes if I remember correct kind of strange looking
#9 cityboy2977 OFFLINE
cityboy2977
    ordinary average guy
  • 117 Thanks
  • 179 posts
Posted October 04, 2011 - 02:29 AM
i would weld a handle to a piece of threaded rod and be done with it, just keep the original pieces for resale.
#10 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted October 06, 2011 - 07:54 PM
Well I was busy today working on the plow mod. Welded 4 short pieces of 1/4 inch angle to the two nuts to make an assembly to keep the nuts from turning and allow them to move the plow mounting arm. Jamed to other nuts to keep the threaded rod in place. Added a handle. Only thing remaining is to finish off the welds, cut the treaded rod to length, buff and paint. I at least have the concept worked out. Seems to do what I want. I can just put the old threaded rod in with the nuts and it's back to original. Yeah!!! Now for pictures.
#11 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted October 09, 2011 - 09:23 AM
Thats a pretty neat fix and I like that you can put it back original hear is a pic of the hitch on mine and I have a white one like yours
#12 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted October 09, 2011 - 07:24 PM
You could do exactly the same thing I did to mine. I would say that your plow is a Ohio Steel Fabrication but with out the removable sleeve hitch. They weld it on solid and added more holes to accomplish the same adjustment as mine. I have to remove and flip it over to get more adjustment where as you just put it in a different hole. I nice thing about the mod I did is I can put the handle forward for the ride on tractor or to the rear for the walk behind.
#13 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted October 09, 2011 - 08:35 PM
Mine will be OK for all I do with it mostly it sets on a self I may plow with it one day just to see how it does.
If you are wondering why I don't use it I was just counting today I have 24 plows I guess I will need to
plow a line and trade to the next plow so I can use them all
What you made looks like it will do well. And you did not trash the plow to do it
#14 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 09, 2011 - 08:48 PM
Do you have any 12 inch sleeve hitch plows?
#15 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted October 10, 2011 - 08:05 PM
I have 2 12" Brinly sleeve hitch plows most of what you see will be the 10"plows
the 12's and 8's are a little harder to find
