Disk ID help
3 replies to this topic
#1 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted September 29, 2011 - 12:03 PM
Just brought this Home last night form Portage MI. Son had to run up to Livonia to pick up some parts for the business he works for. So I did a quick search on craigslist for a plow. Found a plow and disc in Portage so we stopped on the way back and picked it up. I got the manual for the Plow but have no clue who made the disc. I believe the hitch was modified to fit what ever. Any help would be appreciated.
If more pictures are need let me know.
#2 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted September 29, 2011 - 01:14 PM
I am going to guess its a wheel horse disc and would work with the slot hitch wheel horse used.
#3 MH81 OFFLINE
Posted September 29, 2011 - 04:13 PM
It's been modified to work with either a slot hitch (lifting) or "anything with a hitch" (just pulling)
The red sure makes it look like a WH. Wonder what the pigtail was for? A second gang possibly?
#4 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted September 29, 2011 - 06:40 PM
Thanks for the Id it was spot on. I down loaded a WH implement manual. It is for sure a Wheel Horse item. The pigtail was welded on and is going to get cut off. Going to try to take it apart. The shoulder bolts on the top I have been able to loosen up. One is really bad. The adjuster casting is broke and probably not replaceable unless I find another unit or someone that just happens to have a part. The game plan is to remove the hitch bar and make one for a sleeve hitch.
