Will a JD 400 front blade fit a JD 420?
5 replies to this topic
#1 Ribusa OFFLINE
Ribusa
  • 5 posts
Posted September 29, 2011 - 11:04 AM
Does anyone know for certain if a front blade off a 400 will directly fit a 420? Thank you so much and I hope this is not a dumb question
Thank you
Ribusa
#2 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted September 29, 2011 - 03:08 PM
I think the 400 has a wider frame
#3 Littledeere OFFLINE
Littledeere
  • 1,651 Thanks
  • 1,484 posts
Posted September 29, 2011 - 04:45 PM
Not a dumb question but the answer is not easy there is a blade that will and there is a blade that will not without work
#4 big red dog OFFLINE
big red dog
  • 22 Thanks
  • 81 posts
Posted September 29, 2011 - 08:31 PM
Little deere is correct. Download the x595 attachment guide and check your serials....
#5 Ribusa OFFLINE
Ribusa
  • 5 posts
Posted September 30, 2011 - 02:21 AM
Well I invested the two hours it took me to go look at the 400 blade and here is what I found. My 420 has a 16" wide frame and then the "hooks" or lower part of my mount where the blade "hooks" on measures 13" in between the two pieces of 1/4" steel. The 400 blade is designed for a 16" frame at the top of the mount where the spring loaded pins are and is also 16" wide at the bottom.I would have had to move the bottom pins inboard 1 1/4" on both sides to make it work.
I guess I'll keep looking or maybe try to make a mount for my"M02870"
Thank for your replies
Ribusa
#6 big red dog OFFLINE
big red dog
  • 22 Thanks
  • 81 posts
Posted September 30, 2011 - 03:49 PM
Perhaps a new bottom plat... Check e-Bay. I saw one lost week I think was for a 420. Not for sure, but worth a shot in the dark....
