Slot hitch?
12 replies to this topic
#1 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted September 28, 2011 - 01:10 PM
I've come to realize that nobody makes ground engagement attachments for the very proprietary wheel horse slot hitch.:mecry:
I would like to know if a conversion sleeve hitch is available, or if I need to make my own?
If anybody has made one, please post a pic. I have some good ideas of how I think it should be made, but I'm neither a welder or fabricator.
#2 ckjakline OFFLINE
ckjakline
  • 1,144 Thanks
  • 1,135 posts
Posted September 28, 2011 - 03:50 PM
A guy my brother works with made his own.He used whatever size plate steel that fit into slot hitch(maybe 1/4 in).To raise and lower it he ran a cable to where the pin goes into the impliment.He set it up to work with brinly attachments.Sorry don't have any pictures.I'll see if i can get some.
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted September 28, 2011 - 07:31 PM
You can build an adapter, but it does sit the implement back a little further. WH also made a sleeve type hitch. You can find them on epay or build your own. There are several members with them, maybe one of them has dimensions for you.
Here is a thread about a built one: http://gardentractor...ch-i-made-5095/
  • 70Blazer said thank you
#4 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted September 28, 2011 - 08:31 PM
Thanks MH81. That's a nice hitch. I am going to make something that will keep the existing slot hitch intact. It won't look that nice, but it should function and I'll be able to use both style attachments.
#5 MH81 OFFLINE
  • 29,978 Thanks
Posted September 28, 2011 - 08:35 PM
The hitches swap out with 1 pin and the lift cable. If you kept both hitches handy, you could swap pretty easily from what I understand.
#6 Texas Deere and Horse OFFLINE
  • 14,887 Thanks
  • 15,514 posts
Posted September 28, 2011 - 08:54 PM
Blazer, Here is a few pictures of a slot to sleeve adapter. This is an original from Brinly.
If you want some dimensions, I will get them for for. The pictures are not great, went out in the shop and grabbed them for you.
  • MH81 and 70Blazer have said thanks
#7 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted September 28, 2011 - 10:23 PM
That's just what I was thinking of doing more or less. However I have zero fabricator skills and would need whatever I end up with
to be made up for me. The Brinley you show here would be hard to find I would think. Worth looking on eBay though. Thanks for pics. I'll let you know if I need dimensions.
#8 Cvans ONLINE
  • 7,279 Thanks
  • 6,373 posts
Posted September 28, 2011 - 10:46 PM
This will give you an idea of what can be done with your hitch. This sub-soiler and a spring toothed harrow used your hitch. Made it easy to switch from one to another.
#9 Grumpy OFFLINE
Grumpy
  • 747 Thanks
  • 623 posts
Posted September 29, 2011 - 04:04 AM
I have a adapter like the one in Texas deere and horse's picture. Give me a call 8one2 45three-9eight31.
Edited by caseguy, September 29, 2011 - 06:03 PM.
#10 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted September 29, 2011 - 09:09 AM
I will give you a call.
#11 Grumpy OFFLINE
Grumpy
  • 747 Thanks
  • 623 posts
Posted October 09, 2011 - 08:02 AM
70 Blazer, Did you get the hitch OK?
Grumpy
#12 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted October 09, 2011 - 08:39 AM
Grumpy
I sure did thank you. According to postage, I owe you 95 cent lol.
#13 Grumpy OFFLINE
Grumpy
  • 747 Thanks
  • 623 posts
Posted October 09, 2011 - 10:53 AM
Don't worry about it. I'm glad I could help.
