Kenny's Tractor Port
86 replies to this topic
#46 JDBrian OFFLINE
  • 9,595 Thanks
Posted October 03, 2011 - 07:02 PM
It's coming along. It's difficult to tell what you are doing on the north side so it will be a surprise for us when you put the windows in! What did you mean by welding blind?
#47 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted October 03, 2011 - 07:03 PM
Your tractor port is looking great Kenny. Thanks for the updates and pics. I'm sure you will enjoy it when it's finished.
:ditto: Looking just fine!
#48 mjodrey OFFLINE
Posted October 03, 2011 - 07:08 PM
I'll second that Ditto.:ditto:
#49 IamSherwood OFFLINE
  • 8,384 Thanks
Posted October 03, 2011 - 07:17 PM
Looking good Kenny. Does the welding blind issue have anything to do with the can of "Bud" on the table?
#50 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted October 03, 2011 - 07:26 PM
Not the single can Will, but the 7 or so empties in the trash can might! LOL
#51 KennyP ONLINE
  • 33,254 Thanks
  • 42,701 posts
Posted October 03, 2011 - 07:36 PM
On the welding blind, once I strike an arc, I can hardly tell where I am welding. It all just blends together. Daniel, doesn't matter if it's one or a dozen, still cant get that weld where it needs to go. I usually grind off a lot of extra.:D:bigrofl:
#52 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted October 03, 2011 - 07:39 PM
I had to do some welding with my gas powered Lincoln on my cow feeder brackets. Picked up my older welding helmet, not realizing how bad the cover lens were. I could see fair till I struck an arc.....then blind as you were! Gotta pick me up several spare covers.
#53 IamSherwood OFFLINE
  • 8,384 Thanks
Posted October 03, 2011 - 07:41 PM
Well, that's no good.
Do you wear glasses?
Under the helmet?
#54 KennyP ONLINE
  • 33,254 Thanks
  • 42,701 posts
Posted October 03, 2011 - 07:44 PM
Got to have the glasses on, other wise I couldn't tell where the part was to be welded.
#55 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted October 03, 2011 - 07:46 PM
Even a slight haze on the protective lens covers will cause everything to look foggy once you strike an arc. Maybe that's your issue.
#56 KennyP ONLINE
  • 33,254 Thanks
  • 42,701 posts
Posted October 03, 2011 - 07:48 PM
Daniel, do the auto darkening have covers on them? My helmet has the knob on the side turned all the way to darkest, but could use one more notch. If I get out into the sunshine, I can see it all pretty good.
#57 IamSherwood OFFLINE
  • 8,384 Thanks
Posted October 03, 2011 - 07:50 PM
Corrective lenses for the helmet are available. I tried my buddies the other day. What a difference, compared to specs under the helmet.
#58 Alc ONLINE
  • 6,147 Thanks
  • 7,047 posts
Posted October 03, 2011 - 07:56 PM
If I'm understanding you Kenny , your saying your lens isn't getting dark enough for you to watch the arc ? Sounds like that would be very hard on your eyes . Just another question what kind of welder and settings are you welding at ? Thanks , Al
#59 IamSherwood OFFLINE
  • 8,384 Thanks
Posted October 03, 2011 - 08:05 PM
If I understand this correctly, it sounds like you have the knob set to dark.
#60 wvbuzzmaster OFFLINE
  • 4,662 Thanks
  • 7,409 posts
Posted October 03, 2011 - 08:08 PM
Looks like you will have a nice little tractor parking area Kenny, keep it up.
