Cub Cadet. Electric Lift
18 replies to this topic
#16 Billy M OFFLINE
Billy M
  • 736 Thanks
  • 578 posts
Posted February 29, 2016 - 09:38 AM
Funny, I was going to post a thread on parts for a CC electric lift I have.  Motor runs fine, but shaft doesn't move.  It will go, stop, go, stop, go, stop, etc., when I pull or push on the shaft.  Gears I suspect.  I found gears at CC Specialties, but man those gears aren't cheap!
  • classic said thank you
#17 classic ONLINE
classic
  • 5,637 Thanks
  • 2,351 posts
Posted February 29, 2016 - 10:39 AM
Here's a pic of a stripped spiroid gear, and yup, they are costly! This actuator came off of a Cub 147 that was used mainly for snow removal with a QA-36 snow thrower. The bearing on the pinion gear shaft in the actuator was worn, and most likely contributed to the spiroid gear failure. New bearings and bushings would be a must if rebuilding one of these actuators.
#18 Billy M OFFLINE
Billy M
  • 736 Thanks
  • 578 posts
Posted February 29, 2016 - 12:09 PM
Yep...that would cause what my lift is doing.  Judging by the cost of the gears/bearings, I would be better off buying a new linear actuator.
#19 Thorr40 OFFLINE
Thorr40
  • 9 Thanks
  • 19 posts
Posted March 07, 2016 - 01:18 PM
I would like to put an actuator on 127. What size stroke and how many pounds?
