John deere 110 clutch Idler
12 replies to this topic
#1 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted September 26, 2011 - 09:53 AM
On my 1966 110 how does the idler for the secondary drive belt hook to the clutch/brake pedal? Thanks in advance.
#2 willie989 OFFLINE
willie989
  • 5 posts
Posted September 26, 2011 - 05:00 PM
This belt goes to varirator sheave and variable speed control lever, by depressing the clutch-brake pedal the brake band is tightened and variator sheave is moved foward causing primary belt to loosen,hope this helps.
#3 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted September 26, 2011 - 05:46 PM
Thanks, but I was wondering what connects the idler, that tightens the belt, to the clutch brake pedal. let me know if I'm not clear enough.
#4 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted September 26, 2011 - 08:05 PM
Does anybody have some pics. of the underside of a round fender 110?
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 27, 2011 - 09:12 AM
Have you had a look at the parts diagrams on JDParts.com. The should show you how it all goes together.
#6 willie989 OFFLINE
willie989
  • 5 posts
Posted September 27, 2011 - 04:48 PM
I'm not sure what you're asking I have an orignal owners manual for jd 110 it has a complete diagram of all pulleys sheaves and belts etc. I also have a jd110 with 8hp kolher.
#7 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted September 30, 2011 - 08:58 PM
Here is an image of what I'm looking for. http://jdpc.deere.co...geServlet_AltIt shows a little rod and spring coming off the idler how does this hook to the clutch/brake pedal? Let me know if its not clear.:smile1:
#8 Trav1s ONLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted October 01, 2011 - 09:21 AM
To the original post;
If you are talking about the same idler/tensioner I am thinking then it does NOT connect to the clutch/brake/variator.
Since your link did not work can you please clarify? Are you talking about the large pulley that rides on top of the secondary drive belt that runs from the variator back to the transaxle? The part I am talking about is #13 in the pic below. The spring to tension on the belt is #6.
If not then here is the image for the variator:
If this is what you are looking for I can get pics of my '66 later or check the FSM and possibly scan it for you. If it is not in these images then I will post up a few more from JDparts.com.
Edited by Trav1s, October 01, 2011 - 09:28 AM.
#9 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 01, 2011 - 03:32 PM
I'm talking about the idler that rides on top of the secondary belt.Do you know where it hooks up? I fiddled with it today and I think I have it right but it would be nice to be sure.
#10 Trav1s ONLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted October 01, 2011 - 07:55 PM
That would be #13 in the first pic. I will crawl under my '66 tomorrow and check it out for you. Hope to get a pic while I am at it.
#11 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 02, 2011 - 07:45 AM
Thanks, that would be great.
#12 Trav1s ONLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted October 03, 2011 - 08:51 PM
Got pics tonight after I got the garage cleaned up that I could get under it.
#13 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 04, 2011 - 06:03 PM
Thanks for the pics. Those are just what I wanted. Hopefully I'll get it running/driving tomorrow and take some pics.
