? on my 68
4 replies to this topic
#1 KennyP ONLINE
  • 40,859 Thanks
  • 47,088 posts
Posted September 25, 2011 - 06:53 AM
I used the 68 to mow yesterday. Just as I finished up, the engine started to die. Pulled the mower clutch back and it kept running. Tried to put the mower back on and it tried to die again. Need to see if the spindle is binding, bad bearing maybe. Anything else that would cause this?
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 25, 2011 - 07:03 AM
Kenny, if the motor is down on power it would cause this as well. If the mower checks out then the problem is with the motor.
#3 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted September 25, 2011 - 08:41 AM
i was thinking those had a kill switch on the deck engagement, maybe someting is shorting it out
#4 KennyP ONLINE
  • 40,859 Thanks
  • 47,088 posts
Posted September 25, 2011 - 09:44 AM
I found one. Just hope this has that switch. First I will check for a bearing in the spindle.Page49.jpg
Just for clarification, this happened all of a sudden, like I had turned the key off.
#5 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted September 25, 2011 - 09:49 AM
make sure you check out all the wiring, maybe something has rubbed though the wire at a bracket.
