How to clean a gas tank?
20 replies to this topic
#1 fordphan OFFLINE
fordphan
  • 7 Thanks
  • 13 posts
Posted September 22, 2011 - 11:49 PM
I have an older, 1957 I think 350 IH that has been in a shed for a long time. The tires are good and hold air and the motor is free. The gas tank needs cleaning real bad. Does anyone have suggestions as to how to accomplish this? Thanks in advance.
#2 MH81 ONLINE
  • 29,900 Thanks
  • 29,729 posts
Posted September 23, 2011 - 05:26 AM
Dads backhoe is that model. Cleaned it 20+ yrs ago and coated the inside. I think we used washed pea gravel & water for a while then pea gravel without water then flushed a hundred times and coated. We took turns from time to time shaking it, but there are some smart fellas here who have been taking tanks and lashing them to their GT wheel and go mow. Your tank may be oversized for a GT wheel, but the concept is a real time(& arm) saver. Just go at a speed that will allow the gravel to fall.
#3 Bolens 1000 ONLINE
  • 14,219 Thanks
  • 17,846 posts
Posted September 23, 2011 - 06:03 AM
:ditto:
I use the same method, It works great
#4 KennyP ONLINE
  • 34,194 Thanks
  • 43,320 posts
Posted September 23, 2011 - 06:09 AM
That's a pretty cool idea. Need to file that away, just hope I can find it when I need it.
#5 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted September 23, 2011 - 06:22 AM
:ditto: on the stones, worked very good, then re-coated the tank, be carfull with badly rusted ones, uncle was looking at me funny when i did that to a briggs model 6 round tank,
#6 fordphan OFFLINE
fordphan
  • 7 Thanks
  • 13 posts
Posted September 23, 2011 - 02:07 PM
I had done it with the gravel before. I thought maybe someone had come up with some kind of solvent or other way. I know I wore my arms out shaking that tank, it was on a motorcycle. Thanks for the help.
#7 Grumpy ONLINE
Grumpy
  • 685 Thanks
  • 602 posts
Posted September 23, 2011 - 02:18 PM
I have used BBs. They work also.
#8 MH81 ONLINE
  • 29,900 Thanks
  • 29,729 posts
Posted September 23, 2011 - 06:57 PM
They sell this stuff at TSC for $20 per gallon... Haven't gotten brave enough to try.
Evapo-Rust: frequently asked Questions and Answers
#9 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted September 23, 2011 - 10:46 PM
That's a great idea but my neighbors already think I'm strange (OK maybe they know I'm strange). Can you imagine the looks they would give me if I was riding my JD model B around the yard in circles with a large gas tank/maraca strapped to the wheel!?
#10 KennyP ONLINE
  • 34,194 Thanks
  • 43,320 posts
Posted September 24, 2011 - 06:31 AM
Momma would have me committed for doing that!
#11 caseguy OFFLINE
Posted September 24, 2011 - 06:57 AM
...Can you imagine the looks they would give me if I was riding my JD model B around the yard in circles with a large gas tank/maraca strapped to the wheel!?
:bigrofl: Yeah, they look at you funny at first, but after a while they just shake their heads and keep on moving LOL.
#12 poncho62 ONLINE
poncho62
  • 1,093 Thanks
  • 1,406 posts
Posted September 24, 2011 - 07:02 AM
Buy some Muriatic acid, dilute about 5x with water and put that in the tank, sloshing it around for a few hours......that will dissolve the rust.....Be careful with it.
#13 MH81 ONLINE
  • 29,900 Thanks
  • 29,729 posts
Posted September 25, 2011 - 03:54 PM
I was wondering if the electrolysis system would work in the really bad ones, then a minimum amount of shaking would need done.
Get all the fumes out, fill with solution, clamp the neg cable on the outside & drop in a positive electrode that won't touch anything. Let her cook for a few hours.
Looking for opinions here, :anyone:
#14 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,475 Thanks
  • 2,811 posts
Posted September 25, 2011 - 05:10 PM
A lot of guy here take them to the radiator shop and have it dipped in the tank used to clean radiators in. I have cleaned them up by putting a large hand full of 1/4 nuts inside, the ones that dont shale out later, you can get with a magnet.
#15 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted October 02, 2011 - 10:24 PM
Ive used a 2 -3 step process.
First, clean the tank out with a strong soap solution and hot water. If you don't get the grease/oil off the tank walls, you can't get it clean. I usually add a hand full of old lug nuts or some old bolts. Agitate - whatever/however..... Agitating lets the nuts and bolts knock most of the scale off the rusty areas - same as you would wire brush a rusty surface. I use a parts magnet to get any nuts that can't gravity drain out when I am done. Also, while tank is full, look for leaks and pinholes. Fixing those is a whole nother issue!
Second Flush and coat the inside with phosphoric acid or some type of rust converter. Move the tank around every few hours to make sure all interior surfaces get a good coating. Usually let it etch overnight...
Third, flush the tank and rinse with acetone, alcohol, or gas drier addetive- to absorb any left over water in the tank.
Have done this a bunch of times and it always seems to work - but the first step is the most important!!!
