I'm finding that when I lift/lower the mower deck on the 1256 that it only raises 1". I just measured that. Is this correct? It sure seems like that isn't much.
Is it possible that some linkage under there is installed improperly?
It's hard to tell,but that looks the the later type lift linkage.I was kind of hoping you had the earlier style,because they definitely used to wear.Check all pin holes in the linkage,and pins too,for wear.
It seems that your wheels on the back of the deck may be to large. It looks like your deck will not level to the ground due to it. Im no pro here, just a thought!
Thats the linkage on my 77 G10. There are leveling instructions in the manual, I beleive if you adjust the rod on the left side it will help with lift.. Mine does lift more than an inch but not much more.
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
