my first real BOLENS
#1
OFFLINE
Posted September 20, 2011 - 06:43 PM
#2
ONLINE
#3
OFFLINE
Posted September 20, 2011 - 06:59 PM
The pin on the right is the freewheeling pin.It needs to be in to drive the tractor.If you remove it the tractor can pe push or pulled then.The hub on the left is the traction control hub.If screwed in it will lock the hub to the axle and act like a posie reend and is good for tilling and snow plowing.Back it out and will release the hub somewhat and is good for mowing.
#4
OFFLINE
Posted September 20, 2011 - 07:02 PM
Welcome to GTT!
congratulations on getting your Bolens!
We would love to see some pictures when you get a chance
You are correct,
Bolens will not free wheel when the free wheeling pin is engaged. The pin must be pulled out to freewheel.
[ATTACH=CONFIG]21445[/ATTACH]
#5
ONLINE
Posted September 20, 2011 - 07:03 PM
:bigrofl: Your faster then me
#6
OFFLINE
Posted September 20, 2011 - 07:57 PM
As for having an MTD? Shucks, I have aa MTD Cub Cadet as well as my Bolens. The CC just does mowing. For any REAL work, I use the Bolens
#7
OFFLINE
Posted September 21, 2011 - 09:11 AM
#8
ONLINE
Posted September 21, 2011 - 02:19 PM
Let us know if you are still having trouble
#9
OFFLINE
Posted September 21, 2011 - 08:24 PM
The 850 used 2 belts for hi/lo range, and you change from one to the other with a lever on the dash that you move turn and then move in or out. The 1050 used a lever on the 'floor' near the gearshift.
#10
OFFLINE
#11
OFFLINE
Posted September 23, 2011 - 02:53 PM
Also, the model number of the engine will help as well. The 850 should have an S-8D, and the 1051 a TR10D.
Other than having the wrong paint on it, it looks really good. I see that it has the "helper spring" on the attachment lift. You will appreciate that if/when you use the tiller.
That tiller looks to be in excellent shape too. Even better, it has the lift link with it. A lot of those got misplaced over the years, and a lot of folks have had to make their own.
Edited by OldBuzzard, September 23, 2011 - 03:11 PM.
#12
ONLINE
Posted September 23, 2011 - 04:14 PM
You can tell by the Hi/Low range lever and low backed seat.
#13
Guest_jdecker94_*
Posted September 23, 2011 - 04:39 PM
#14
OFFLINE
Posted September 24, 2011 - 09:11 AM
Edited by reddragon, September 24, 2011 - 09:20 AM.
#15
OFFLINE
Posted September 24, 2011 - 09:59 AM
yeah the motor is a s-8d......and all thats left on the frame tag is serial# 7798?......its really hard to read but the white on the hood says Bolens 850....iy took 2 days before i even realized
.......also....it was made in jan '66.....so maybe a '65...dont know:rolleyes:............another thing....the headlights are just lenses with no wiring or bulbs....is that normal?........sheetmetal is perfect....just needs paint....the guy just painted the white bits black
The 850 was made from '66-'69, so it couldn't be a '65. To narrow it down a bit further, according to the Sonnys Bolens site, there were different model numbers on the S-8Ds in the 850s.
66 - 231552
67 - 271995
68 - 271995
69 - 285662
Yours isn't the first Bolens to have the wrong paint on it. I don't know if it happens with the other brands as much, but if sure seems like folks LIKE to paint these old Bolens every color under the sun.
If you haven't played with/used any of these old Bolens, the amount of work that they can do will amaze you.
