Shaw Du-All -6
  • This topic is locked This topic is locked
13 replies to this topic
#1 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted September 20, 2011 - 02:53 PM
I don't know what this engine was used on but it had all of the electrical components attached to it.
I removed them so the engine looks nicer.
The round gas tank will be mounted on the front of the engine over the starter/generator.
Here's all the parts that were removed from the engine.
When this was a walk behind garden tractor, it needed a long gear shift lever so the operator could shift it.
As a riding tractor, it doesn't need the lever that long so I shortened it some.
The end of the lever is threaded. ...
And a gear shift knob is attached to it.
The rear frame rails stick out a ways past the wheels.
These were shortened some also.
This tractor is plenty heavy enough up front with that big Wisconsin engine mounted on it.
The rear of the tractor is rather light though.
So I'm going to use this counter weight that use to be mounted on the front and remount it over the rear axle.
It weighs 130 pounds.
I fastened two pieces of angle iron across the frame rails.
One piece is in front of the axle and the other is behind the axle.
The weight sits in-between the frame rails on these two pieces of angle iron and is bolted to the angle iron to hold it in place.
There is about 1/8 inch clearance between the top of the weight and the round rod that holds the brakes.
There is 1/4 inch clearance between the bottom of the weight and the axle.
#2 olcowhand ONLINE
  • 37,225 Thanks
  • 30,213 posts
Posted September 20, 2011 - 04:31 PM
So your seat will mount on that base just above the transmission? That weight looks like it would weigh more than it does! And putting the fuel tank toward the front will balance the looks of the engine.
  • jdcrawler said thank you
#3 mjodrey OFFLINE
Posted September 20, 2011 - 04:45 PM
I tell you,that is going to look sweet when it's done.I really enjoy following these builds that you do, Ray .
#4 cookiemonster OFFLINE
cookiemonster
  • 408 Thanks
  • 1,274 posts
Posted September 20, 2011 - 05:14 PM
What's on the output side of the engine that will go back to the axle? A long belt?
Very interesting.
#5 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted September 20, 2011 - 05:22 PM
Very interesting.
Yes .. it will have a long 5/8 belt to drive the transmission.
#6 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted September 20, 2011 - 05:27 PM
The weight is a solid piece of cast iron that is 28x6x3.
I have no idea what it was originally used for.
#7 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted September 20, 2011 - 05:54 PM
Ray, between these updates, you have to be standing there scratch your head. When you do post an update, everything is spelled out and documented. You have to think about all this sometime.
Great update, keep them coming.
#8 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted September 20, 2011 - 06:14 PM
Coming along Ray, looks good. What color will the Wisconsin be painted?
Peter
#9 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted September 20, 2011 - 06:18 PM
Peter
It will be the factory gray that a lot of the older engines were painted.
I'm thinking I might switch the starter/generator so it sets up closer to the engine ....
#10 mjodrey OFFLINE
Posted September 21, 2011 - 04:53 AM
I think the starter/generator looks better in this last position,closer to the engine.
#11 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted September 21, 2011 - 05:43 AM
I think you are right, pulling the starter/generator up and in looks good, it should tuck in under the gas tank as you said you were putting that to the front side of the engine if I'm remembering..... lookin' good!!
P.
#12 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Posted September 21, 2011 - 06:24 AM
:ditto: on the starter, genny, looking very good,
#13 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted September 22, 2011 - 08:06 PM
I don't know how big the fuel tank is, but I think your original placement of the S/G will allow the tank to sit a little lower. Of course, if it's gravity fed, higher is better.
#14 MH81 ONLINE
  • 28,896 Thanks
  • 29,270 posts
Posted August 28, 2016 - 08:49 AM
Next phase of project can be found here
http://gardentractor...-shaw-du-all-7/
