Tubing a Payloader Tire
7 replies to this topic
#1 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted September 20, 2011 - 02:35 PM
Been putting a tube in our left front Cat 910 payloader tire. The rims are tubeless with a huge o-ring that seals under the removable rim bead (2pc rims w/lock ring). Never could for sure find the leak, but I had pumped it up pretty tight yesterday, so it may have resealed. Anyway, I just slapped a tube in it, as the seat for the o-ring is fairly rough, even after intense cleanup the last time. Took an hour to wrestle the tire off the rim. Whenever I have another start leaking at the bead, they also get a tube.
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 20, 2011 - 02:51 PM
Man there is work I do not miss anymore
#3 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted September 20, 2011 - 03:12 PM
Daniel ,We did the same thing with the tires on out Galion Crane. I got tired of fighting those heavy A$$ tires on and off, and making sure I didn't pinch the O-ring. It will wear your butt out in a hurry..
#4 mjodrey OFFLINE
Posted September 20, 2011 - 04:48 PM
I have done a ton of tires at my shop over the years,but never a payloader tire,and I don't believe I would want to.
#5 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted September 20, 2011 - 08:26 PM
that foam stuff would probly be a good thing to put in a tire like that
#6 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted September 20, 2011 - 08:31 PM
Definitely would be good thing....but expensive! And I'm cheap..........but not easy!:bigrofl:
#7 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted September 21, 2011 - 09:22 PM
lol just fill it with cement, itll never go flat again!
#8 Cvans OFFLINE
  • 7,289 Thanks
  • 6,377 posts
Posted September 21, 2011 - 09:28 PM
Those O-rings are one huge pain in the A$$. One little piece of anything will make them leak and your always working on them out in the dirt. I can't imagine trying to get one to stop leaking in a wet muddy situation. I hope I never have to look at another one.
