FrankenPanzer - Build Thread
51 replies to this topic
#16 Bolens 1000 OFFLINE
  • 14,978 Thanks
  • 18,135 posts
Posted September 29, 2011 - 05:21 AM
Great Work so far! :bounce:
#17 mjodrey OFFLINE
Posted September 29, 2011 - 05:34 AM
Dean,you're coming right a long,looking good.
#18 caseguy OFFLINE
  • 1,628 Thanks
Posted September 29, 2011 - 06:38 PM
That's some nice fabrication work Dean! I think that's a Tecumseh gas tank...maybe from a Wheel Horse by the looks of it...anyway looking great! Keep up the great work!
#19 MH81 OFFLINE
Posted September 29, 2011 - 07:50 PM
Looking very good! That's going to be a nice GT when you're done.
#20 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted October 05, 2011 - 07:46 PM
Thanks for all the compliments, guys. It's going okay so far, just need to try and keep from hurrying to get to the end and do a good job. Not so much mechanically - I just tend to hurry over the looks part... and I hate to do bodywork. Tecumseh tank, huh? Well, it's orangy, but not a briggs kind of burnt orange/brown. Makes sense, I guess. Anyway... more progress:
Well the engine has been mounted for some time, but now I got the PTO control lever and rod installed and modified. Put new wheels on. BTW, this tractor had taken a heck of a hit to the right front at some point in its past. The right front wheel was all welded up and wobbly. The mower deck is still kind of crooked and I'll be straightening that out sometime later. I also finished connecting the mower lift to the old-style T70 rear mounted handle, and I welded a heavy-duty turnbuckle in it so the lift is adjustable.
I'd mentioned before about making a shroud for the ugliness of how I modified the steering. Well, here it is. Just took some time and bent up some 22ga steel to wrap and mount to the backside.
Welded in a new top to the sprocket cover. Bad news is that before I'd realized I'd done it, I'd put 22 ga steel in there instead of 16. It's going to be kind of wavy when it's done because of it. Oh well, but what's done is done. I put the rear lift parts from the t70 on as well, including the "teeth" that go on the frame rail. Had to take apart the right-rear brake because the lever wouldn't return far enough back up to let me use the parking brake. Turned out to be just grass clippings laying on top of the shoe. The drive/reverse control lever was worn pretty bad where it pushes the shaft left or right to tension the belt or contact the reverse. Put some weld on it and ground it down to make a new face. Will help with the drive/reverse adjustment.
Well, that's all I can think that I've done since the last post. looks-wise progress has slowed to a crawl while I took care of those things I mentioned. Time to strip down for some more bondo, sanding, primer and paint. Did I mention I hate bodywork? A necessary evil I guess. Maybe I'll get a day to work on it this weekend...
#21 mjodrey OFFLINE
Posted October 05, 2011 - 08:07 PM
Yes sir,looking real good.
  • cookiemonster said thank you
#22 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted October 09, 2011 - 10:29 PM
Did my painting. Man, it's been a long time since I've used Sherwin Williams paint. Last time, it was interior home paint, but this was the first time I've used their automotive stuff. And it is just as impressive. I go out to look at it every hour or so and it looks better and smoother each time I see it. Now wish I could say the same for my bodywork.
Anxious to put it together tomorrow. Think I'll yank the mower deck so I can start working on it sometime. It needs some spots replaced and/or welded and generally just needs gone over.
#23 mjodrey OFFLINE
Posted October 10, 2011 - 06:48 AM
Hey Dean,get them pictures up.:D:D
#24 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted October 10, 2011 - 03:25 PM
That's funny. Spent the morning putting the painted parts back on. It looks and runs good. Funny thing is that now my wife wants me to paint the frame and stuff so that it looks good, too.... Someday.
Took the mower off cause it will be the next thing to get worked on. The sun glare from the brand new paint didn't help things with the pictures.
And when I was in the "manage attachments" thing, I saw this in my pictures library just to remind myself what the body metal looked like just a few short weeks ago.
#25 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted October 10, 2011 - 08:01 PM
nice job. I love it. now all u need is a stack on it or rear exhaust like i want to do
#26 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted October 10, 2011 - 09:02 PM
Thanks. Funny you should say that. I have a Harley Davidson muffler like new that's going to go on there someday. It's pretty far down the list on the to-do's though.
#27 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 10, 2011 - 10:07 PM
Great looking Panzer, that engine sticking out is cool.
#28 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted October 11, 2011 - 08:06 PM
Thanks. Yeah, the Honda GX390 type into a panzer is a neat fit. I had to extend and modify the engine mount, trim the recoil starter shroud where it met the steering, make a new belt retainer, and trim one of the oil fill caps to clear the drive. A gx270 type would probably be easier, but figured if I was going to go through the trouble, may as well go big. Test drove it around the yard in high gear idling.
#29 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted October 12, 2011 - 03:43 PM
wow that engine has more power than the original. mine boggs way down in 3rd pully
#30 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted October 13, 2011 - 07:23 AM
I ran with the 7hp engine for a day before removing it. It seemed to be good on power. You're probably short on compression and in need of a rebuild.
I'm going to put the 7hp engine on craigslist. Probably tomorrow so that when people call I can show it to them over the weekend or even next week as I'm off work. Even the one I have has paperwork that it got a new short block in the past. Those engines will last forever but do need rebuilds. Sometime getting a short block is cheaper and better if the crank or bearings have worn out.
I would have kept the 7hp just fine, but the wife and boy have shown interest in mowing, and neither would have appreciated the pull-start.
