john deerre 60
15 replies to this topic
#1 derek collins OFFLINE
derek collins
  • 6 posts
Posted September 18, 2011 - 08:40 PM
hi im new to this ha i was wondering if anyone could help me with my john deere 60. i restored it about 1.5 years ago and it ran fine until i switceh the wires to the motor and burtn every thing out of it i got all the new parts put back on but the coils. it ran but put new coils on and now cant get it to run. what should i do repower or have a technecian look at it cant decided
#2 grnspot110 ONLINE
grnspot110
  • 4,093 Thanks
  • 2,619 posts
Posted September 18, 2011 - 09:12 PM
The 60 & 70 are not that easy to re-power! They used 6 & 7 HP Tecumseh engines with a stepped crank to fit the deck clutch. So either the crank or clutch will have to be redone to fit, if you want to use the deck. Without the deck an 8-12 HP Briggs can be used without a lot of trimming. ~~ grnspot
#3 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted September 18, 2011 - 10:44 PM
If you disconnected the kill wire from the motor and there is no spark the coil is generally no good
#4 derek collins OFFLINE
derek collins
  • 6 posts
Posted September 19, 2011 - 06:36 AM
that is my problem i cant figure out where the two wires go and the flywheel keeps hittin the coil assembly and bending it up. i was wonderiing what would be the hardest thing about repowerin a 60. i would love to put a li biger motor but i still want it to look original like that old look.
#5 derek collins OFFLINE
derek collins
  • 6 posts
Posted September 19, 2011 - 03:40 PM
ive been told that i could get a regular briggs and bolt it on and just bolt the stepped pulley on it from the underside it would be great if it was that simple like no trimmin or anything
#6 Texas Deere and Horse OFFLINE
  • 14,729 Thanks
  • 15,470 posts
Posted September 19, 2011 - 03:53 PM
derek, It's your tractor, do what you want. If it were mine, I would take it to someone how has worked on GT's a good while and have them fix it. If you want more power and want it to run for several more years, with no restoration value, then re-power it. I try to keep as many of the GT's stock as I can. But that just me.. Good Luck !!!
#7 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 19, 2011 - 07:37 PM
I agree with texas deere and horse. These little tractors are getting harder to find, especially with the original motor in it. If it were mine, I'd find, and pay someone to try and fix it first. If it can't be fixed, then maybe I'd think about the re-power option. Just my two-cent worth.
#8 derek collins OFFLINE
derek collins
  • 6 posts
Posted September 20, 2011 - 06:00 AM
how much does it hurt the value without the original motor?
#9 grnspot110 ONLINE
grnspot110
  • 4,093 Thanks
  • 2,619 posts
Posted September 20, 2011 - 06:34 AM
For re-sale, quite a bit. Collectors usually want original equipment! ~~ grnspot
#10 derek collins OFFLINE
derek collins
  • 6 posts
Posted September 26, 2011 - 08:15 PM
Does anyone on herer no how to adj. the timing on a tecumseh with the coils under the flywheel without feeler gagues?
#11 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted September 27, 2011 - 06:36 PM
Derek, to set the points without using a feeler gauge use the doller bill trick, folded in half is around .030 of an inch, best of luck and join us again in chats,
#12 derek collins OFFLINE
derek collins
  • 6 posts
Posted September 28, 2011 - 06:31 AM
will do trowel ill be timing it probly this weekend ha and hope the best. ill keep u guys updated
#13 Trav1s ONLINE
Trav1s
  • 3,160 Thanks
  • 4,274 posts
Posted September 30, 2011 - 08:37 AM
Setting the timing on the Tecumseh V/VH series engine is a real treat. I picked up a nice original 60 that I sold to a friend who is getting it running. From what he told me I will stick with Kohlers ;-)
http://www.smallengi...k_reference.pdf
Some thoughts on the VH engines
John Deere Tractor Collectors
#14 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted October 02, 2011 - 08:22 AM
Thanks for the post Trav1s, very good reading and info. there,
#15 Trav1s ONLINE
Trav1s
  • 3,160 Thanks
  • 4,274 posts
Posted October 03, 2011 - 03:05 PM
You bet! :D
