OLD Lincoln stick welder
22 replies to this topic
#16 Big John OFFLINE
Big John
  • 24 Thanks
  • 96 posts
Posted September 21, 2011 - 10:44 AM
Daniel, is that Lincoln welder of yours a Weld-an Power? If so I was given one about
five years ago. The motor was toast so I did a repower with a 17hp Onan. It took 4 days t o make the adapters to fit the Onan to the generator. Then I replaced the ignition & starter toggle switchs with a key start switch. T he toogle switches were shot because they are not rated for DC use. The only thing wrong with it now is no power to the throttle control solenoid.:yelclap:I went to my welding supply house & they had Lincoln fax them a wiring diagram for my unit. The diagram price was right-FREE.
Edited by Big John, September 21, 2011 - 10:50 AM.
#17 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted September 21, 2011 - 10:57 AM
Brian (TDH), does his still have the markings across the top where the needle goes? Mine are MIA. I just give it a guess. Thought if I could get a pic of one with the #'s still showing, I might see if I could make up something for Daniel to make a decal from.
Sorry Kenny, Just read this. I will take a picture and make drawing of it so you can get it replaced.
#18 olcowhand ONLINE
  • 40,327 Thanks
  • 31,166 posts
Posted September 21, 2011 - 05:22 PM
Yes, but a 150 model, powered by a Kohler K301 single. Mine has manual throttle settings/no solenoid. Is yours a 225 then?
#19 caseguy OFFLINE
  • 1,627 Thanks
Posted September 21, 2011 - 06:24 PM
That's a great piece Kenny! Just a little bit of trivia, the older welders are heavier because they're wound with copper coils. The newer models generally have aluminum coils and cannot handle the same sustained current as the older ones. The copper ones always seemed to create a smoother arc too, but that's just my humble opinion.
#20 olcowhand ONLINE
  • 40,327 Thanks
  • 31,166 posts
Posted September 21, 2011 - 06:46 PM
:ditto:
#21 Big John OFFLINE
Big John
  • 24 Thanks
  • 96 posts
Posted September 21, 2011 - 07:48 PM
Original motor was 16hp B&S. Weld power is 225 A. ac , dc, dc rev. AC power is 7000 watts at 115 or 230 volts. Motor had rod trashed.
How do I get this post to appear below yours.
Edited by olcowhand, September 21, 2011 - 07:59 PM.
#22 olcowhand ONLINE
  • 40,327 Thanks
  • 31,166 posts
Posted September 21, 2011 - 08:01 PM
I did it for you, but all you have to do to quote me is on the lower right of the post you wish to quote, hit the "Reply with Quote".....then it pops up ready to add your part.
  • Big John said thank you
#23 KennyP ONLINE
  • 37,389 Thanks
  • 45,445 posts
Posted October 28, 2011 - 04:23 AM
I know you have been busy and probably have forgotten this. It would be nice to have the #s back up there, I have a pencil line drawn on top to give me an idea where to start and adjust from there. When you have time, I would be happy to have this.
