Here I Go Again! Dump Trailer Time!
314 replies to this topic
#76 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted September 24, 2011 - 09:50 AM
Brian, I am going to hold off building until I get the 'tractor port' up. Then I will have more room to work on it. That is scheduled for right after the first of the month, depending on weather.
#77 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted September 24, 2011 - 04:58 PM
Kenny, is that the carport you got earlier this year? I had forgotten about that. It's a pretty big job if I recall correctly. I'd like to see the progress if you get a chance to do a thread on it.
#78 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted September 24, 2011 - 05:10 PM
Sure is, Brian. I am slowly finding new homes for all I have under the current lean-to in preparation for the switch.. Yeah, a thread would be good. Then you all can have a good laugh at what I have to work with. Just kidding!
I am currently redefining some of what I have drawn, as issues have arisen that I couldn't/didn't see before. That's why I like to draw out things, gives a different perspective.
#79 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted September 25, 2011 - 09:13 AM
? for any engineers out there. Which would be better to make the lift bars (what raises the bed for dump), 3/8" X 2" bar stock or 1 1/4"/1 1/2" black pipe? The black pipe is cheaper and easier to get.
#80 ducky OFFLINE
  • 1,988 Thanks
  • 4,107 posts
Posted September 25, 2011 - 10:10 AM
Not an engineer but I think the black pipe would work fine.
#81 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted September 26, 2011 - 12:09 AM
Thanks, ducky. I was thinking the pipe would give more side motion support that bar stock won't.
#82 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted September 28, 2011 - 07:58 PM
Here is an update of the drawing thus far. I have changed the lift bars to black pipe, 1 1/2" for the lower & 1" for the two uppers. I have also opened the front of the frame for the cable to run through. Has a ways to go and I will probably change a few things yet, but it's looking pretty good.
I moved the lower lift attachment closer to the tongue, giving a better angle when it starts lifting. Here's a side view from DeltaCad.
That's all for now.
#83 MH81 OFFLINE
Posted September 28, 2011 - 08:01 PM
Really good Kenny, now to start a build thread.
#84 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted September 28, 2011 - 08:05 PM
Gotta get the 'tractor' port done first. Lots more to do there. If I don't fill it up too quickly, I'll have lots of room for building this.
#85 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,642 Thanks
  • 5,045 posts
Posted September 28, 2011 - 08:47 PM
I know this will take all the fun outta the build but I have one o these and I think its the best of both worlds. It sits low enough to load without any problems [wheels outside the box so low and stable] and yet still dumps completely. It really does flip all the way over like in the pic.
Dump Cart
#86 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted September 28, 2011 - 09:25 PM
Dump Cart
But you still got to pick it up and dump it by hand right? Is it a handful with heavy loads?
#87 Alc OFFLINE
  • 7,124 Thanks
  • 7,530 posts
Posted September 28, 2011 - 09:27 PM
That's a really neat way to dump a trailer , Al
#88 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted September 29, 2011 - 03:07 AM
Gtractor, neat dump cart. Probably works good with the two wheeler. I think it wouldn't work too well behind a GT. I don't quite understand how you start dumping it. Thanks for posting it.
#89 mjodrey OFFLINE
Posted September 29, 2011 - 04:37 AM
That's a neat dump cart Gtractor,thanks for posting the photo.
#90 HDWildBill OFFLINE
  • 8,978 Thanks
Posted September 29, 2011 - 10:48 AM
I loving this thread. I looking forward to the see what the finial result is. I may have to do the same with my cart or Kenny you could commercialize.:bounce:
