Shaw Du-All -5
  • This topic is locked This topic is locked
26 replies to this topic
#16 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,398 Thanks
  • 1,765 posts
Posted September 19, 2011 - 07:47 AM
Is that the same as the Original Cub used?
I don't really know what this one fits.
The one I have is way too tall and I need a shorter one.
#17 Alc OFFLINE
  • 6,318 Thanks
  • 7,157 posts
Posted September 19, 2011 - 08:05 AM
Ones on my JD318 aren't very tall but I don't know if using a pair close together would work for you , Al
  • jdcrawler said thank you
#18 KennyP ONLINE
  • 34,244 Thanks
  • 43,366 posts
Posted September 19, 2011 - 08:34 AM
Ray, measured the one on the Sears GTV/16. It is just a little over 3" tall. Hope that helps.
#19 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,398 Thanks
  • 1,765 posts
Posted September 19, 2011 - 12:38 PM
I have a pair of springs and they won't work.
It needs to be a single spring.
The 3 inch would work OK but the top and bottom of the spring needs to be parallel to each other.
I've looked at a couple of Sears springs but the spring mounting area on those Sears tractors sloped back at an angle so the springs wasn't parallel.
Does the GTV16 slope back ?
#20 KennyP ONLINE
  • 34,244 Thanks
  • 43,366 posts
Posted September 19, 2011 - 06:44 PM
Looks rather parallel to me. This is a 1981, so they may have changed them a bit from the older ones. If I had an extra, I'd send it to you.
The pic makes it look sloped, but the bottom of the seat is nearly flat where the spring attaches.
#21 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,398 Thanks
  • 1,765 posts
Posted September 19, 2011 - 07:47 PM
Thanks Kenny
I appreciate that information.
I think I saw a spring for one of these tractors on ebay and I'm going to go see if it's still there.
#22 KennyP ONLINE
  • 34,244 Thanks
  • 43,366 posts
Posted September 20, 2011 - 06:28 AM
Ray, I hope it works for you. Don't know of one any shorter.
#23 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted September 20, 2011 - 06:38 AM
jdcrawler, i have been learking around here for a bit and had a thought, can you use a truck leaf spring, throw it in the forge and bend it to what you need, you could do some cool bends with it, if you was closer to me i could modify the existing one you have to 3 inch high on my forge,
#24 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,398 Thanks
  • 1,765 posts
Posted September 20, 2011 - 07:05 AM
wouldn't heating it take all the spring tension out of it ?
#25 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted September 20, 2011 - 07:33 AM
no, let it normalize after heating, the old springs from 1950's, 60's and 70's are high in carbon and fluxed with nickle and magnezium, heat to a low red, just enugh to bend it to the shape you need and so you don't oxidize the carbon out of it by too many high white heats, the new steel depending on grade (ex. : 4034) have to be tempered to blue or purple for springness, i pulled out my note book and it states :1960"s chevy 1 ton truck spring is same as chevell and impala cars in grade, grinder sparks sparkle in 6 to 8 little sparks meaning the magnesium is burning when ignighted by the grinder, grade 6 to 8 spring,
i make garden tools out of the springs, takes 5 tons to snap it, good stuff,
#26 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted September 20, 2011 - 07:44 AM
oh, right, my bad, by grade 7 to 8 spring steel, i mean 150 point steel, i was tought old school,
#27 MH81 ONLINE
  • 29,922 Thanks
  • 29,743 posts
Posted August 28, 2016 - 08:43 AM
Next phase of project can be found here
http://gardentractor...-shaw-du-all-6/
