Shaw Du-All -5
  • This topic is locked This topic is locked
26 replies to this topic
#1 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted September 14, 2011 - 10:00 PM
When I pulled the drive pulley off the transmission, the back side of the pulley was caked with grease.
The input shaft doesn't have any kind of shaft seal on it.
I'm going to make this oil seal to fit on the drive shaft using this piece of aluminum.
One side of the aluminum is bored out so the seal will press into it.
The other side gets a bronze bushing pressed in it to keep the seal centered on the shaft.
The new seal is fastened onto the end of the transmission with a section of hard rubber hose.
These are the motor mounts.
They are notched on each end so they can slide into the frame rails.
The first motor mount is being squared up with the transmission drive shaft.
Both mounts are welded to the inside of the frame rails.
Here's the engine mounted in place.
  • 14,810 Thanks
  • 15,499 posts
Posted September 14, 2011 - 10:15 PM
It's really coming along Ray. Once again this thingis going to be a real eye pleaser.
  • jdcrawler said thank you
#3 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Whats the big wisconsin?
#4 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 15, 2011 - 03:48 AM
Neat seal idea! It's looking good with the engine up there.
#5 mjodrey OFFLINE
Posted September 15, 2011 - 04:21 AM
She's lookin' like a tractor now.
I just wish I could get motivated to get at some of my projects.
Edited by mjodrey, September 15, 2011 - 04:31 AM.
#6 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted September 15, 2011 - 05:03 AM
Looking Good Ray
#7 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted September 15, 2011 - 05:28 AM
More nice work Ray, nice "fix" on the seal.
Peter
#8 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted September 15, 2011 - 07:43 AM
The tag is missing so I don't know for sure but I think it is an AEN, AENL or AENLD.
If it is, then it is a 8 or 9 HP engine.
When I got the engine I thought it was an AEH like the one on my Agricat crawler.
This engine it the same height and shape as the AEH but the carb and exhaust are on the opposite side as the AEH.
There was an AENLD on ebay and it looks exactly the same as this engine.
I don't know how to tell what the engine is without a tag on it.
Edited by jdcrawler, September 15, 2011 - 07:50 AM.
#9 mjodrey OFFLINE
Posted September 18, 2011 - 09:01 AM
What kind of steering mechanism are you going to use ?
#10 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted September 18, 2011 - 04:35 PM
I'm going to still use the Ford model-T steering column that was on it.
They had the end of the steering shaft connected directly to one of the front spindles.
This made the steering rather quick and it would be easy to have the steering wheel jerked out of your hands if the front tires hit a rock or a rut.
So I'm thinking of fastening the model-T steering shaft to a small steering box.
This should make it easier to steer.
#11 mjodrey OFFLINE
Posted September 18, 2011 - 05:26 PM
Yes,that should work just fine.
#12 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted September 18, 2011 - 09:58 PM
I need some help ...
I'm looking for a seat spring sort of like this.
It needs to be about 4 inch high.
I haven't had any luck finding one that high on ebay yet.
If you have one for sale, please send a photo to my email at:
jdcrawler@yahoo.com
Thanks
#13 Texas Deere and Horse ONLINE
  • 14,810 Thanks
  • 15,499 posts
Posted September 18, 2011 - 10:03 PM
Is that the same as the Original Cub used?
#14 MH81 OFFLINE
Posted September 19, 2011 - 01:05 AM
How about a riser? I have 2 MH tractors that were apparently owned by taller individuals at one time. They put a piece of steel 1.5" thick under the seat spring, raising it up where it's more comfy. Maybe a solution if you can't find one a full 4"
#15 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 19, 2011 - 05:08 AM
Ray, my GTV/16 has one close to that tall. It will be later before I can get a measurement for you.
