Case 444 hydraulic tank question
2 replies to this topic
#1 1949f1 OFFLINE
1949f1
  • 1 Thanks
  • 11 posts
Posted September 14, 2011 - 03:28 PM
I have a 71 444 and have a hydraulic tank that is mounted under the battery. I am not sure if it is the correct tank. I have found a couple different ones on the internet and it looks like the one under the battery has the one hose comming out at an angle but both hose nipples are straight down on mine and the inlet fitting on the pump is angled which is a problem with the hose. I also found a tank on e-bay that mounts above the cooler. I am having trouble with the travel acting like it is starving for fluid which looks to be the line from the tank to the pump being kinked. I can not seem to find a hose that will work and not kink.
Can anyone steer me in the right direction as to which tank is right? Or has the pump been changed
Thanks
#2 Alc ONLINE
  • 6,903 Thanks
  • 7,468 posts
Posted September 14, 2011 - 07:49 PM
Can't help you but maybe a picture of your tank and what the problem hose looks like might help those who can , Al
#3 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted September 14, 2011 - 09:16 PM
Put a spring inside the hose
