I'm at a loss, need as much help as I can get here.
23 replies to this topic
#16 olcowhand ONLINE
  • 42,469 Thanks
  • 31,825 posts
Posted September 14, 2011 - 09:25 PM
Actually, if the crank has NO end play whatsoever, then there could be pressure on the bearings by being pre-loaded. If the bearings are too tight, they will make weird knocks too.
#17 Alc ONLINE
  • 7,129 Thanks
  • 7,532 posts
Posted September 15, 2011 - 05:44 AM
Can't wait till you find the cause of this problem !!! Didn't some engines have some kind of compression release ? Could that make a knock if there was a problem with it ? Al
#18 BillTheTractorMan OFFLINE
BillTheTractorMan
  • 205 Thanks
  • 288 posts
Posted September 15, 2011 - 05:46 AM
I'm pretty sure it's the rod, based on the scoring now.
Will the crank and rod from a HH100 work in a HH120?
#19 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 15, 2011 - 10:03 AM
[ATTACH=CONFIG]21099[/ATTACH]
Bill
I would plastigage the rod bearing just to be sure.
I might also consider reringing as you will never get the rings back in there original location. Just to not make an oil burner.
#20 BillTheTractorMan OFFLINE
BillTheTractorMan
  • 205 Thanks
  • 288 posts
Posted September 15, 2011 - 03:28 PM
plastigage?
I can't afford to put any money into anything right now as it is, I just need it to make it through this winter so I have something to move snow with. I'm plowing 3 driveways, mine and two neighbors that are elderly. If it burns some oil, fine by me. Next summer is when I will be able to work on things and hopefully have some money to put into it as the tractor needs work too.
#21 DH1 ONLINE
DH1
    Electric Tractors
  • 5,379 Thanks
  • 5,611 posts
Posted September 15, 2011 - 06:11 PM
the rods are the same HH100, 120.
#22 BillTheTractorMan OFFLINE
BillTheTractorMan
  • 205 Thanks
  • 288 posts
Posted September 15, 2011 - 07:48 PM
Would the crank match too?
Right now I'm looking at $59 alone to have the crank repaired, not sure on the rod yet. new parts are going to cost at least $300 form what I have found.
#23 DH1 ONLINE
DH1
    Electric Tractors
  • 5,379 Thanks
  • 5,611 posts
Posted September 15, 2011 - 07:50 PM
Cranks are different, HH120 has longer stroke.
#24 BillTheTractorMan OFFLINE
BillTheTractorMan
  • 205 Thanks
  • 288 posts
Posted September 15, 2011 - 09:45 PM
Ok, thanks. I got a tip to use some emery cloth on the current crank and get it smooth, than take the hh100 rod and put it on and turn it by hand listening for a knock. than go off that.
