Brinly 6 1/2" Plow Question - Pics included
23 replies to this topic
#16 steve b OFFLINE
steve b
  • 121 Thanks
  • 220 posts
Posted September 20, 2011 - 10:05 AM
trowel,
Heres a few shots of my plow. You simply drop the pin through the hitch on rear of tractor. The other post fits into the socket near the top of the handelbars and secures with a pin.
Steve
Edited by steve b, September 20, 2011 - 01:39 PM.
putting pics in order
#17 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted September 21, 2011 - 06:20 AM
Steve b, thank you for the picture, now that is a very different plow from all the others, nothing to do with brinley at all, can you post the model no. and serial please along with the Mfg. date if you can,
in your previous post you said that you think you have it set up, i have never used one of these plows but have a pretty good ideas how to set it up to your tractor if you want to try,
#18 steve b OFFLINE
steve b
  • 121 Thanks
  • 220 posts
Posted September 21, 2011 - 08:05 AM
I believe I have the owners manual, I will check.
Date should be 1951. I have seen no numbers on the plow, but will look harder.
Steve
#19 steve b OFFLINE
steve b
  • 121 Thanks
  • 220 posts
Posted September 21, 2011 - 06:20 PM
The model # is Mid-5603.
#20 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted September 22, 2011 - 07:32 PM
ok, i was wondering why, i was thinking simplicity model c tractor, for the most part took the same plow as your plow trac, the MID in the model no. threw me off, is that the 6 inch or 8 inch, i can't tell,
#21 wobbly OFFLINE
wobbly
  • 6 Thanks
  • 22 posts
Posted September 30, 2011 - 07:52 PM
Steve, What make and model tractor does this plow fit? It is like a three point hitch and would have to be easier to control than a single pin hitch. I am enthralled.
Best to you....Wobbly
#22 steve b OFFLINE
steve b
  • 121 Thanks
  • 220 posts
Posted October 01, 2011 - 09:17 AM
trowel, I think it is 6" I will measure later.
wobbly, plow fits Montgomery Wards Plow Trac. It is really only supported in 2 points. The 2 bars on either side of the beam connect to a central pin.
That pin mounts to the handlebar of the tractor. Take a look at the pictures I posted, I believe you will see what I mean.
Steve
#23 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted October 02, 2011 - 07:21 AM
Thanks steve, no hurry on it, do you plow with it ?
#24 steve b OFFLINE
steve b
  • 121 Thanks
  • 220 posts
Posted October 05, 2011 - 06:46 AM
Not Yet, Just got a cyclebar mower ( thanks to a fellow GTT member) which I am hoping to get going for spring.
My tiller workd fine in my 30x30 garden for the time being.
