1971 JD 110 Mower disengages
3 replies to this topic
#1 kasperd OFFLINE
kasperd
  • 1 posts
Posted September 13, 2011 - 01:46 PM
I recently acquired a 1971 John Deere 110. It has a leaking gas line, and an oil leak, but seems mechanically sound otherwise. I tested it out on a small patch of grass, and noticed that when I hit small bumps, the lever would pop out of the notch, and the mower would disengage. Is this something that just needs adjusting. The only manual I found was for the round fender model, and I have the square fender, so I have not been able to find a manual. Any help would be appreciated, as it's a bit clumsy to drive and hold the lever in place :-)
Thanks
#2 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted September 13, 2011 - 08:00 PM
Welcome to GTTalk kasperd. I bet that you have a broken spring. It is located under the battery tray and is to hold tension on the pto lever. You will have to pull the battery and tray to get to it.
Good luck,
Mark
#3 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted September 13, 2011 - 09:47 PM
Welcome to GTtalk. Hope you found the answer the question.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 14, 2011 - 09:21 AM
Welcome and good luck with the PTO problem. Let us know what you did to get it fixed.
