Shaw Du-All -4
  • This topic is locked This topic is locked
8 replies to this topic
#1 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,858 Thanks
  • 1,848 posts
Posted September 12, 2011 - 08:17 PM
I'm going to use these two tapped holes in the top of the transmission for mounting the base plate for the seat.
This is one of the brackets off a truck camper for the jack stands.
I've bent the front edge to fit the angle of the mounting pads on the transmission.
Here I'm fitting the seat base in place.
Drilling the front mounting holes in the seat base.
The original walk behind garden tractor had a cast frame support on the back of the tractor frame.
It mounted in one side of the frame then went up, across and down to the other side of the frame.
You can see the rear frame support in this photo.
I took that rear frame support, turned it around and used it to support the rear of the seat base.
With the seat base in place, I then mounted the seat spring to the seat base.
Turns out that this seat spring is going to make the seat set too high.
I found a spring on ebay that is about half this height so the seat will end up sitting about 4 inch lower.
While I was in front of the tractor and eyeballing the seat, I realized the front of the frame is welded on to the frame rails at an angle.
It is about 3/8 inch higher on the one side.
The front cross plate is also out of square to the frame rails by about 1/4 inch.
So I cut the front cross plate off.
Then I took a long pipe and used it to twist the frame rails into place.
The frame rails are now level.
The sides are cut off the front plate so I'm left with just the center axle mount.
Using the pieces that I had cut off the back of the frame rails to shorten them, I'm trimming them to fit at an angle between the frame rails and the front plate.
Here is the new front frame design.
  • 14,730 Thanks
  • 15,470 posts
Posted September 12, 2011 - 08:20 PM
Ray, I see we are in for another fantastic built from you. Can't wait to follow along on the journey. Thanks for sharing with us !!
  • jdcrawler said thank you
#3 KennyP ONLINE
  • 37,396 Thanks
  • 45,448 posts
Posted September 13, 2011 - 06:21 AM
Ray, I love to read about your work. Very informative and simple. Thanks for the update pics.
#4 DougT ONLINE
DougT
    Dog Approved
  • 6,847 Thanks
  • 4,949 posts
Posted September 13, 2011 - 09:19 AM
Ray, I like the front axle. It makes it look more like the real thing.
#5 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,858 Thanks
  • 1,848 posts
Posted September 13, 2011 - 09:59 AM
I'm glad now that I didn't see that the front was off kilter before I shortened the frame.
If I had, I would have just straightened it before I welded the frame back up and would have most likely just left that wide flat front plate on it.
#6 caseguy OFFLINE
  • 1,627 Thanks
Posted September 13, 2011 - 10:07 AM
Thanks for bringing us along on another one of your fantastic projects Ray! It looks to me that the new design not only looks better, but it will also allow fuller pivot travel on uneven terrain! Looking good as always Ray!
#7 mjodrey OFFLINE
Posted September 13, 2011 - 02:54 PM
Ray,as usual,nice work.:thumbs:I will be following this one very closely.
Edited by mjodrey, September 13, 2011 - 02:59 PM.
#8 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted September 18, 2011 - 08:28 AM
wow, im loving this, i like how you did the axle mount/frame rails much better then before, looks GREAT,
#9 MH81 OFFLINE
Posted August 28, 2016 - 08:42 AM
Next phase of project can be found here
http://gardentractor...-shaw-du-all-5/
