the ht20 is looking lonely
20 replies to this topic
#16 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted September 12, 2011 - 12:09 AM
... i alreayd have the wheel off and i whaled on it for a bit with crapswoman screwdrivers. ...
If I remember right, I used a big old carriage bolt that was pretty close to the diameter of the pin, and a 4# hammer.
It's still gonna take some penetrating fluid of some sort to give you that little bit of extra 'help' though.
#17 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted September 12, 2011 - 01:11 AM
All but the hood sounds great! I think you are taking it better than I would have though!!!!! :)
#18 Jehtro OFFLINE
Jehtro
  • 111 Thanks
  • 276 posts
Posted September 12, 2011 - 09:00 AM
Man, thats awesome a G14 with a factory lift kit,
That was the biggest problem I found with my G14, but man it was the best snow blower I've ever owned, the gear drive gave it traction like crazy.
Where is the lift control?
#19 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted September 12, 2011 - 03:54 PM
actually since the 38" blower fits on the ht 20's pto. i might have it customized to fit my ht20 whats really sad is i had to bury a dog. and i didnt have gas in my ht to fill the hole back in with the blade =(
#20 Jehtro OFFLINE
Jehtro
  • 111 Thanks
  • 276 posts
Posted September 13, 2011 - 04:08 PM
it knocked the whole hood out of whack. so someone doesnt realize it but there costing me alot of money. but hopefully if i can get a key switch it'll be good enough to drive.
i had to replace the iginition switch on my h14, i ended up using a standard 4 pole switch and added a master kill switch. let me know if you want my custom modified wiring diagram, its on a nail in my shop, but i could scan it in.
#21 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted September 13, 2011 - 09:13 PM
so i put a keyswitch in. it has the main shape so the harness fits on it. but its only 2 position so when it clicks to on the lights go on. but i only get spark erratically so lets hope i dont need a whole new ignition.
