LGT 165 Deck Lift Redo
4 replies to this topic
#1 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted September 07, 2011 - 07:04 AM
I was talking about this in my front axle thread, but thought I would move the actual repair here. I found the bronze bushings a McMaster-Carr and picked these:9368T55. Here are the specs:Material
Bronze
Bronze Type
Graphite SAE 841 Bronze
Type
Sleeve Bearings
For Shaft Diameter (Inside Diameter)
3/8"
Inside Diameter Tolerance
+.0010" to +.0020"
Outside Diameter
3/4"
Outside Diameter Tolerance
+.0020" to +.0030"
Length
1"
Length Tolerance
±.005"
Load (P Max)
1,600
Speed (V Max)
1,000
Load at Speed (PV Max)
40,000
Temperature Range
-30° to +700° F
Now I have to figure the best way to cut these in half so they are only 1/2" +/- long. May try a tubing cutter I have. They shouldn't be too hard to cut.
Here are the original bushings and shoulder bolts they will replace:
If anyone has a better way to cut these in half, let me know.
#2 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted September 07, 2011 - 07:11 PM
Got the bushings today. Cut them in half and installed them. Tightened the lift mechanism up real nice. Here's a few pics.
Here is a pic of the worn cross shaft and the 'new' replacement piece.
Should be a much better lift with all the slop gone. Now to drag out the blade and finish the handle on it.
#3 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 29, 2012 - 05:13 PM
But you didn't say if that took care of the problem or not.
Dick
#4 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted December 29, 2012 - 06:09 PM
Dick
It helped, but you are stuck with only so much lift as the bar will hit the under side of the axle. I think I had another thread somewhere on the blade.
EDIT: Here's the blade re-do thread.
#5 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 29, 2012 - 07:52 PM
That blade sure has a lot of little parts, like a puzzle. That is something you need to take pictures of prior to disassembling.
Dick.
