pulley nut on 214 mower deck
5 replies to this topic
#1 MacWorld ONLINE
MacWorld
  • 93 Thanks
  • 122 posts
Posted September 06, 2011 - 01:09 PM
Hi,
First of all I hope I am in the right forum to post my question.
I am rebuilding my 214's 39" mowerdeck and I am at the point where I need to torque the 3x 1.125" nuts to hold the pulleys to the blade's shaft. It should be torqued to 120lbs/ft but how do JD engineers think we should hold the shafts from turning? I am not even able to go to 60lbs/ft holding the blade!
Currently my plan is to make a tool which I would screw at the place of the blade with a 4' arm but before doing it, did someone has a better way of doing this?
Also, do I really have to torque those nuts to 120lbs/ft? To me it seems quite a lot.
Thanks!
#2 caseguy OFFLINE
  • 1,629 Thanks
Posted September 06, 2011 - 06:02 PM
:wave: MacWorld Welcome to GTTalk! I usually get a chunk of 4X4 and wedge it between the blade and the deck. I haven't ever done this on a JD deck, but it works on Bolens and Wheel Horse decks. Hope that this helps. Since you're here, why don't you pop over to the Member Introductions forum and tell us a little about yourself and your hobby(s)? Thanks for signing up!
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 06, 2011 - 06:42 PM
Welcome to GTTalk MacWorld. I asume you got the 120ft/lb figure form a reliable source and it is the recommended torque. You need to hold the blade from turning as caseguy indicated above. You may need to get a second person to help out. You don't want them coming loose on you!!
#4 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted September 06, 2011 - 09:53 PM
Are you doing this on the bench or on the deck?
I use a large pipe wrench (18" or larger) on the blade end and use my electric impact.
You can also use a vise to hold the blade end. I would use a electric or air impact. My old impact will put it around 100 pound. The lock washer is not going the release the nut at 100 pounds.
#5 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted September 06, 2011 - 10:19 PM
I just hold the blade and use a impact and tighten them to were i feel good.Never hade one come off.
#6 MacWorld ONLINE
MacWorld
  • 93 Thanks
  • 122 posts
Posted September 13, 2011 - 02:06 PM
For future reference if someone wants to make a tool, there are pictures of what I did in my "introduction thread"
http://gardentractor...8978/#post95829
