JD 318 fill front tires
2 replies to this topic
#1 buck50bmg OFFLINE
buck50bmg
  • 1 Thanks
  • 37 posts
Posted September 06, 2011 - 11:31 AM
Just wondering if filling the front tires would be worth the effort? How much weight could be realized?
Thanks
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 06, 2011 - 11:47 AM
Not a lot. You can get front wheel weights also for some sizes but I don't know if Deere made them. You may be better off trying to add some weight to the front of the tractor somewhere.
#3 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 06, 2011 - 11:49 AM
An 18x850x8 should hold 1.5 to 2 gallons. About 15 to 20 lbs depending on the fluid you use. Avoid Calcium Chloride like the Plague. Extremely corrosive. Rim Guard (Beet Juice) come in at 10 lbs a gallon to get the most weight.
