Lack of grease zerks -- Simplicity Prestige 4X4
4 replies to this topic
#1 Steve Meyer OFFLINE
Steve Meyer
  • 5 posts
Posted September 06, 2011 - 01:11 AM
In poring over the detailed parts manual for my new Simplicity Prestige 4x4 I found a total of one grease zerk on the tractor mower combinatiuon -- on a weldment holding the shaft of an idler pulley.
None on the blade arbors/spindles, steering mechanism, etc.
I'm currently unable to inspect this for myself (I have an knee operation in a few weeks) but it's hard to believe Simplity's pretty detailed manuals.
Any experienced comments?
Steve Meyer
#2 mjodrey OFFLINE
Posted September 06, 2011 - 04:19 AM
The only thing I can say is,they don't make stuff like they used to.Grease fittings were everywhere at one time,and as long as you greased them,things would last a long time.
#3 Orangeman05 OFFLINE
Orangeman05
  • 16 Thanks
  • 67 posts
Posted September 06, 2011 - 10:07 AM
Steve Meyer
Steve- Believe me there are several zerks. I've attached a pdf of my Simplicity Manual with the grease and lubrication points. You want to look at page 30.
Matt
Edited by NUTNDUN, September 06, 2011 - 11:12 AM.
  • Bolens 1000 said thank you
#4 MUDDAWG OFFLINE
MUDDAWG
  • 6 Thanks
  • 43 posts
Posted September 06, 2011 - 05:35 PM
although Im not familiar with your brand of mower deck
my swisher tow behind came with no grease fittings when they wore out
I replaced the bearings in the spindles , by removing the inside dust cap,
drilling 2 small holes in the outer dust caps and drilling and tapping the spindle in a convienient location for a grease fitting
I can now effectively grease , non greasable /sealed bearings in my swisher deck
hope this will help your situation
mike
#5 Powerwagon896 OFFLINE
Powerwagon896
  • 6 posts
  • Location: On the Tundra of Northern New York State, Almost Canada Eh?
Posted September 07, 2011 - 06:06 AM
mike
My old Gilson decks were the same way. I also drilled & tapped the spindle housing in a convienient location on top side of the deck.
