AVCO New Idea EGT200
150 replies to this topic
#16 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted September 05, 2011 - 11:22 AM
That site is full on info and is a sticky in the GE Forum here.
>My Elec-Traks - Index
Thanks for that link. I had no idea that there were that many models. I bookmarked that site. I need to go back and check out all the info.
#17 DH1 ONLINE
DH1
    Electric Tractors
  • 5,366 Thanks
  • 5,605 posts
Posted September 05, 2011 - 01:25 PM
Spent some time today to see what I got here, tried to mount both attachments and both are missing small parts to make them work. Of course I never seen or worked on these tractors before so it's a learning process to.
Pictures.
#18 IamSherwood OFFLINE
  • 8,395 Thanks
Posted September 05, 2011 - 01:42 PM
What would that be comparable to in a gas GT? Size Hp ?
#19 DH1 ONLINE
DH1
    Electric Tractors
  • 5,366 Thanks
  • 5,605 posts
Posted September 05, 2011 - 01:47 PM
I'm not sure I think they say 18hp???
I can see why they would make a good Garden tractor, you sit on top of 4 batteries 250lbs, plus the main drive motor is mounted behind the rear axle, all of this extra weight right on top of the rear wheels is not there on a gas tractor.
#20 IamSherwood OFFLINE
  • 8,395 Thanks
Posted September 05, 2011 - 01:50 PM
No wheel weights req'd.
So is it about the size of a MF14?
#21 DH1 ONLINE
DH1
    Electric Tractors
  • 5,366 Thanks
  • 5,605 posts
Posted September 05, 2011 - 01:53 PM
Smaller about the size of the 10s, 12s, lower hood height but it probably weighs the same or more than the 14s, 16s.
#22 IamSherwood OFFLINE
  • 8,395 Thanks
Posted September 05, 2011 - 01:59 PM
You should make up easily removeable dual stacks for it. Round up some business for the hearing doctor, when your neighbors see you cutting
the lawn.LOL
#23 DH1 ONLINE
DH1
    Electric Tractors
  • 5,366 Thanks
  • 5,605 posts
Posted September 05, 2011 - 02:00 PM
Picture of it's belly.
#24 IamSherwood OFFLINE
  • 8,395 Thanks
Posted September 05, 2011 - 02:10 PM
That's in good shape.
And no grease/oil to clean up.
#25 IamSherwood OFFLINE
  • 8,395 Thanks
Posted September 05, 2011 - 02:13 PM
Well, summer is over. And I'm outta here for a day and half. I've had enough
of the tourists for another year.(28th year) Talk to yas when I'm back.
#26 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted September 05, 2011 - 02:20 PM
Doug, You got a great machine. Hope you get all the attachments figured out. Good luck.....
#27 DH1 ONLINE
DH1
    Electric Tractors
  • 5,366 Thanks
  • 5,605 posts
Posted September 05, 2011 - 04:40 PM
Now for the bad rust, from what I gather and have seen in pictures battery box rust is a big problem, this one is no exception.
Inside each battery box there is a plastic try on the bottom, then a plastic bag lines the box, then the batteries go in.
This is what mine looks like.
The best preserved part of the tractor, underside of the hood.
#28 DH1 ONLINE
DH1
    Electric Tractors
  • 5,366 Thanks
  • 5,605 posts
Posted September 05, 2011 - 05:01 PM
This tractor came with a 42" rear discharge mower, I tried to mount it and found some parts missing that I'll have to find or make up.
The lift strap is not there, 1 of the 4 L shaped arms is missing and a 3 link piece of chain.
This mower uses the electric lift on it.
2 of the 3 motors turn freely the other is very stiff, but overall a solid deck.
#29 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted September 05, 2011 - 05:12 PM
Doug, that looks like a Peerless transmission. If so, it should be relatively easy to get parts for it. There is a bit of rust damage but the panels seem to be all straight, by that I mean not curved, which will make it easier to weld patches in or make new panels. Overall it is in pretty good condition.
#30 DH1 ONLINE
DH1
    Electric Tractors
  • 5,366 Thanks
  • 5,605 posts
Posted September 05, 2011 - 05:27 PM
I also got a 36" wide snow blower that has wings on it to give it a 44" width overall. The blower is in really good shape, turns nice and free, has the shoot rotater that works, the scraper edge has next to no wear on it the skid shoes are set low and are worn out, looks like this thing will work.
It is missing a few parts that I'll have to get.
The bracket that goes on the front bumper for the lift strap.
2 small brackets for the lift assist springs.
The front strap for the lift.
Some pins.
The biggest problem I have is the black main mounting bracket, it slides into the slots in the tractors frame, there is suppose to be pins or a rod that goes though the bracket and the frame to hold it in place.
The problem is there are no holes in the tractors frame for this. I don't know if this is the right bracket or not??? Are you just suppose to drill the frame for it to work??? That would solve the problem.
I don't know what I'm going to do with this blower, I'll never use it, I'm thinking about selling it and put the $ towards new batteries.
