Manual Needed for Thermo King Engine
11 replies to this topic
#1 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 03, 2011 - 10:07 AM
Does anyone have a manual for a Thermo king KD Max II with a TK 373 engine.
The engine was build exclusively for TK by Yanmar to TKs specs.
I at least need bore, stroke, and displacement and service info for the fuel pump.
Any help would be greatly appreciated.
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 05, 2011 - 07:59 AM
:bump:
#3 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted September 05, 2011 - 08:35 AM
I don't know if you will have much luck finding the manual here. Does Thermo King have any literature available?
#4 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 05, 2011 - 08:38 AM
Thx George
Thought I might luck out and run into a TK wrench here.
#5 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted September 05, 2011 - 08:49 AM
I searched, but found nothing.
#6 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted September 05, 2011 - 08:52 AM
I was hoping you would get lucky too Ducky. With diesel conversion just starting to take off I don't think all avenues have been explored.
Did you happen to try calling a Thermo King dealer?
#7 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,437 Thanks
  • 5,619 posts
Posted September 05, 2011 - 09:11 AM
Are there any names or #s on the injection pump itself?
Maybe searching that way might give some info on adjustments.
I take it tour looking to increase the governed RPM and turn up the fuel a bit.
#8 MH81 OFFLINE
  • 29,979 Thanks
Posted September 05, 2011 - 09:43 AM
This is for a larger motor, somewhere around pg 190 it shows the pump, but not a ton of info. Wish I could've found more for you.
http://www.florens.c...ions Manual.pdf
#9 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 06, 2011 - 07:45 AM
Right now I would like to increase RPMs a bit. It smokes like a steam engine right now under load so fuel is not an issue. I am investigating a turbo charger as an option to use some of that fuel.
#10 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 06, 2011 - 08:11 AM
Thx Everybody. I will see if a TK dealer will give me anything. Just don't have any connections in the reefer business.
#11 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,437 Thanks
  • 5,619 posts
Posted September 06, 2011 - 06:29 PM
Not familiar with your inj pump but on some some it's as easy as a limit screw on the throttle, just like the idle speed and if it smokes like you say you don't need more fuel.
#12 Rick Brumback OFFLINE
Rick Brumback
  • 19 Thanks
  • 124 posts
Posted September 16, 2011 - 06:44 PM
Look for a tk dealer in your area,they can tell you exactly how set it up.
