In-Line Primer for Fuel Pump (SS/16 Twin)
5 replies to this topic
#1 dthomp17 ONLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted September 01, 2011 - 08:50 PM
:smile1: I have a Sears SS/16 Twin that has the gas tank under the seat and a fuel pump that will lose its prime after sitting several days. Once it loses prime, I have to disconnect the gas line from the carburetor, attach a funnel with a gas line to the carb and start the engine from gas in the funnel. Then I disconnect the funnel and reconnect the gas line from the tank, usually spilling a little gas in the process. I have an old fishing boat with an outboard motor and remote gas tank. I happened to have an extra fuel line primer bulb for the boat. I decided to try this outboard primer bulb in the gas line from the tank to the carb to see if it would work. It worked great. Now when I lose prime, all I have to do is squeeze the bulb three or four times and I'm in business. This might work for you if you have similar problems.
#2 ncb OFFLINE
ncb
  • 52 Thanks
  • 215 posts
Posted September 01, 2011 - 08:53 PM
Great idea, how about a few more pics of the GT, motor looks so clean
#3 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted September 01, 2011 - 09:11 PM
I have a GT rigged the same way. And was afraid to tell about thinking folks would laugh But it WORKS. And WELCOME to GTtalk and join some of us on chat.
#4 KennyP ONLINE
  • 38,296 Thanks
  • 45,894 posts
Posted September 02, 2011 - 04:01 AM
I just love the problem solving on this forum. Yeah, I laughed first. But if it works, use it.
#5 jwrezz OFFLINE
jwrezz
  • 1 posts
Posted January 29, 2016 - 02:50 PM
I just went to start my tractor for first time in weeks actually two months. Cranked for about 1.5 minutes until prime returned. This is my first fuel pump tractor and I thought why not have a primer bulb like two strokes? That's how I found this forum! Such a waste of battery life. I wonder if there is an alternative. Or a kit already out.
#6 MNGB ONLINE
MNGB
  • 2,114 Thanks
  • 1,405 posts
Posted January 29, 2016 - 07:46 PM
I had a similar problem with my SS16, I installed an electric fuel pump and disabled the pulse pump also work good, the primer bulb is a simpler and less expensive fix.
